Moneybox Posted December 9, 2024 Posted December 9, 2024 How much does it take to keep a small aircraft (310kg) tied down? Today I braved 44°C to do a little more work on the Sportstar. We took a quick trip south that lasted 10 days and arrived home Saturday. I had to buy the brass hose tails for the new mechanical pump and when I picked up the post I got the carburettor sleeves so that just about finishes the work to be done. I'm still waiting on engine mounts but I don't think that will prevent it being passed for registration. Now I have to consider the problems faced in fitting the wings at the airport and tying it down once that's done. I don't think there are any anchorage points out there so I'll have to provide my own. I have some steel for a dozer blade, one at 100kg and two at 35kg each. I think if I put an anchorage point onto each one they'd do the job? We get some really wild weather here and there are no hills, buildings or trees to break the wind. Any suggestions?
rgmwa Posted December 9, 2024 Posted December 9, 2024 One trick I've heard about but haven't tried is to lay thick rope along the wing to break up the airflow and the lift. Sounds plausible. 1
Moneybox Posted December 9, 2024 Author Posted December 9, 2024 Mmmmm..... might work but I guess you'd like me to try it first? 😁 1
rgmwa Posted December 9, 2024 Posted December 9, 2024 Can’t do any harm if your tiedowns are a bit dodgy.
Thruster88 Posted December 9, 2024 Posted December 9, 2024 Cut off steel posts or star pickets work. Drill out the top hole and use a shackle for the rope. 1
skippydiesel Posted December 9, 2024 Posted December 9, 2024 At "home" I have three Star Pickets driven, as far as I could, into the ground. You may need to borrow/purchase a post driver (I call it a "donger") and the Star Pickets Place your aircraft where you intend to park it - mark the points where you will drive the pickets in. Remove aircraft to do the driving. Drive the pickets, at an angle away from (not straight down as in fencing) the aircraft tie down location. This is the same concept as pegging a tent . The tail picket is left as is, with the two wing pickets reduced (cut off) to easily clear the underside of the wings. Smooth the cut off edges, they are razor sharp & will do a lot more than bark your shin, if you inadvertently make contact. I go to the next level and put a plastic high viz cap on each picket. The tail picket is perhaps .5m behind the tail ( you may go further back for your nose wheel aircraft/tail in air). The two wing pickets are placed, so that the tie down straps are in front of the wing and at about 45 degrees out from the wing tie down. The concept is to remove all slack (without undue tension) on all three straps. I use cam buckle load rated straps, with metal hooks at each end, purchased from Bunnings Aerospace, to do the tying down bit. You may find that the hole in the star picket will have to be enlarged to accommodate the hook. After tensioning down the strap, I use the surplus strap to go round both ends of the hook eye and tie off, as added security A D shackle or two may help with the tail tie down. I carry a separate lightweight kit for temporary tying down, when on an away trip. 1
Tasmag Posted December 9, 2024 Posted December 9, 2024 The main thing to account for is what the wing can lift, not what the aircraft weighs. MTOW would be a good starting point. I don't think that 170KG of steel would come close to doing the job. Mike 1
facthunter Posted December 9, 2024 Posted December 9, 2024 You're just toying with the problem. The plane(s) should be secure in a hangar built strong enough to withstand any likely winds and then some. Your "Bird" IF you MUST have a tie downs do it properly. Big enough cement Blocks flush with the ground and a ring to lift and tie to. The PLANE may still be there but damaged and overstressed.. Nev
onetrack Posted December 10, 2024 Posted December 10, 2024 Most Western Australian red dirt with moderate clay content sets like concrete in Summer. You're struggling to drive star pickets into it. I've found modified Hilti concrete bolts ("screw anchors") work for me, for anchoring items in hard W.A. ground in Summer. The Hilti concrete bolts normally require an undersize hole drilled into concrete, and the bolt them screwed straight in. But that's not practical in dirt, so I grind the end of the Hilti bolt to a taper, which assists in starting them into the ground. You drive them in with an impact wrench, and you'll need a minimum of 200mm length, probably 300mm is better. Slip a big heavy washer under the head prior to installing, and use a neat-fitting D-shackle under the washer as the anchor point. /_ui/package/100336/responsive/assets/images/logo_2016_sRGB.png HUS4-H screw anchor - Mechanical Anchors - Hilti Australia WWW.HILTI.COM.AU Hilti Mechanical Anchors - HUS4-H screw anchor - High performing hexagonal head screw anchor for fastening to concrete and masonry (carbon steel) 1
skippydiesel Posted December 10, 2024 Posted December 10, 2024 "Most Western Australian red dirt with moderate clay content sets like concrete in Summer. You're struggling to drive star pickets into it. I've found modified Hilti concrete bolts ("screw anchors") work for me, for anchoring items in hard W.A. ground in Summer." Is the above system good for when the ground is soaked?😈 1
skippydiesel Posted December 10, 2024 Posted December 10, 2024 Whatever system is used - Its asking for problems if the aircraft can move on its restraints. Doesn't matter how secure/heavy the anchor. I often see aircraft tied with loose restraints - the wind/gusts will start to jerk/move the aircraft - once this starts, damage can be done to the aircraft. The jerking may also break the straps/ropes or loosen the anchor. 1
onetrack Posted December 10, 2024 Posted December 10, 2024 Whenever the ground gets soaked - a rare event in the W.A. Goldfields - you have to re-appraise your hold-down method. In which case, the star pickets will probably prove a better hold-down system. The ground can go from concrete-like to extremely soft once it gets soaked, and that applies anywhere.
facthunter Posted December 10, 2024 Posted December 10, 2024 Why be there when it's soaked? Would the drome still be serviceable? Nev 1
dlegg Posted December 10, 2024 Posted December 10, 2024 4 hours ago, facthunter said: Do you fit Gust locks? . Nev Mandatory or you're in for a nasty surprise 1 1
Bosi72 Posted December 10, 2024 Posted December 10, 2024 This worked for me before got in a hangar.. 2 1
kiwiaviator Posted December 10, 2024 Posted December 10, 2024 This is a very informative publication with some great ideas for 'mooring' your aircraft to mother earth https://www.aviation.govt.nz/assets/publications/gaps/secure-your-aircraft.pdf I had my Jabiru 230 tied down in Newman just up the road from you one winter. I used the Claw tiedown system. In the summer I stored it in a hanger in Geraldton as there was no way I was having it outside in wet season. You should seriously consider some sort of hanger. The container shelters are cyclone rated and cost effective. I would have permanent tie downs as well in them. 3
Moneybox Posted December 10, 2024 Author Posted December 10, 2024 Thanks for all the great suggestions. Our shire look after the airport so I had a meeting this morning with the CEO. He said that there are no anchorage points out there but suggested I take a look at the concrete blocks lying off to the side. I have to look into who owns them. I have the hooks somewhere to fit onto these anchor points so they might do the job for now. I don't think I can drive star pickets in but I do have a thumper if I need to use it. I like the look of the Ground Grabber bolts but the Hilti ones might be just as good in this ground. You never know what it's like until you actually try to drive something in. I often peg ground to claim the lease so I carry wooden and steel stakes. Sometimes I can't get a steel stake in the ground but then 50m away a stake needs to be driven deep just to remain standing. Same thing when its wet. I've been parked overnight during the rain and woke up to find the tyres a few inches down. Other ground remains rock hard. 2
Moneybox Posted December 10, 2024 Author Posted December 10, 2024 https://peggypeg.com.au/products/peg-stop-heavy-duty-screw-peg-20-cm-p-s-hd-pack-of-4?variant=42099294011587&country=AU¤cy=AUD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&adv_go_camid=18405330892&adv_go_groupid=&adv_go_adid=&adv_go_keyword=&adv_go_matchtype=&adv_go_proid=shopify_AU_7408015835331_42099294011587&gad_source=1&gclid=CjwKCAiA6t-6BhA3EiwAltRFGBQJVKYC_q72zkMJt9SRS0r7wCFrFshLJ7_RE4Wbbtkmxe6OOuDd4BoCDe8QAvD_BwE I like the way these type of things can be removed if necessary. Four of these are $55 but they are only 200mm long and that might not be enough in soft ground?
KRviator Posted December 10, 2024 Posted December 10, 2024 23 hours ago, Thruster88 said: Cut off steel posts or star pickets work. Drill out the top hole and use a shackle for the rope. That's what I carry on away trips. I have 3 x 30cm star pickets with D-shackles on 'em and a mallet. Bit heavier than I'd like, but carried as far aft as I can get 'em gives me an quarter-knot TAS increase.😃 1 1
skippydiesel Posted December 10, 2024 Posted December 10, 2024 31 minutes ago, KRviator said: That's what I carry on away trips. I have 3 x 30cm star pickets with D-shackles on 'em and a mallet. Bit heavier than I'd like, but carried as far aft as I can get 'em gives me an quarter-knot TAS increase.😃 To me there is a big difference between a permanent tie down and a traveling tie down system. The permanent is a 12 month, all seasons/conditions structure, without weight restriction. The permeant can be very secure The travel system should be compact, lightweight and easy to set up/remove. The travel unit is a compromise, that is unlikly to stand up to severe wind conditions. The cautious pilot will have avoided tying down (traveling) his aircraft in this sort of weather. I see travel systems that are reasonably compact & light weight BUT then need a good sized hammer or even cordless drill, to install - questionable advantage. I see a lot of permanent and travel systems that use cheap string to secure the aircarft (most often slack) - this is counting pennies while dollars are potentially lost. 3
Freizeitpilot Posted Monday at 04:23 AM Posted Monday at 04:23 AM At a council-owned airfield, is it common practice to allow semi-permanent tie-downs to be installed (like deeply driven star pickets) at your allocated space, if you are renting the space for a month or year ? The ‘allocated spaces’ regularly become waterlogged just to add insult to injury.…and no, there is zero hangar space available probably for the next decade. The council has a reputation for being antagonistic toward the airfield, so I don’t want to formally enquire, if there is a risk of being declined. 1
facthunter Posted Monday at 04:32 AM Posted Monday at 04:32 AM I've seen rings mounted to a long concrete beam level with the ground surface. That would work OK. Councils attitudes to Aerodromes is extremely Variable. I'd quietly make contact with other users on the way to go about things and then go upfront. Nev 1
Moneybox Posted Monday at 05:24 AM Author Posted Monday at 05:24 AM We have a bitumen parking/runup bay. When speaking to the shire CEO he said there was some talk of running a heavy chain right through the area for tiedowns but so far nothing has been done. If I push it I have no doubt they'll help do something here in Cue. We get wild gusts of wind quite often because we have extreme temperatures and no hills or trees to break the wind. No plane would be safe left untethered. Mine is still in the back yard. 1
BrendAn Posted Monday at 07:45 AM Posted Monday at 07:45 AM (edited) i am confused, are you keeping it the shire airstrip. i thought you were flying out of your place. at west sale airport they have concrete blocks you just drag out to where they are needed and tie the plane to them. the wind howls through there and they work fine. Edited Monday at 07:48 AM by BrendAn 1
