danny_galaga Posted December 12 Posted December 12 I'm nearly at the end of my paperwork. But also at the end of my tether. I've supplied an invoice for my prop, but because they haven't heard of that brand need more info. This is the manufacturer: http://www.p-propeller.co.za/ My invoice has a serial number and prop size. Makes me laugh about the thread for making your own propeller since it seems it's not legit if ra Aus have never heard of it 🙄 I've half a mind to sell my prop as a decoration and buy a Sensenich. Wonder if ra Aus are familiar with that little cottage business... 1
Thruster88 Posted December 12 Posted December 12 Yeah but the Sensenich may not be approved for your aircraft, then you will need a marup and another $600. 🤨 I miss the good old days.
danny_galaga Posted December 12 Author Posted December 12 (edited) Kit plane.. doesn't come with an engine or propeller. Surely whatever you fit, it is the correct propeller? Edited December 12 by danny_galaga 1
facthunter Posted December 12 Posted December 12 If it gives the required thrust and doesn't over rev the engine and It's wood. you should be good.. Nev
Blueadventures Posted December 12 Posted December 12 44 minutes ago, danny_galaga said: I'm nearly at the end of my paperwork. But also at the end of my tether. I've supplied an invoice for my prop, but because they haven't heard of that brand need more info. This is the manufacturer: http://www.p-propeller.co.za/ My invoice has a serial number and prop size. Makes me laugh about the thread for making your own propeller since it seems it's not legit if ra Aus have never heard of it 🙄 I've half a mind to sell my prop as a decoration and buy a Sensenich. Wonder if ra Aus are familiar with that little cottage business... Did you advise them its owner build not a factory build?
danny_galaga Posted December 12 Author Posted December 12 34 minutes ago, facthunter said: If it gives the required thrust and doesn't over rev the engine and It's wood. you should be good.. Nev You would think so. Fingers crossed. I'll get more info from the manufacturer, including his star sign and favourite beer. 1 1
skippydiesel Posted December 12 Posted December 12 (edited) Agree with the inference made by Blue. As the builder, you can put a V8 & a dometic fan blade on the front if you wish - it may not pass its safety inspection or get off the ground but those are two other matters/hurdles. People have crafted their own prop - how did they manage to be aproned????😈 Edited December 12 by skippydiesel 1
facthunter Posted December 12 Posted December 12 Looks like a good place to get one. RAAus is not supposed to be more strict than CASA would. You'd probably be OK if you had a DH 82 on VH . Silly. Nev
Thruster88 Posted December 12 Posted December 12 59 minutes ago, facthunter said: Looks like a good place to get one. RAAus is not supposed to be more strict than CASA would. You'd probably be OK if you had a DH 82 on VH . Silly. Nev As you would know, the DH 82 tiger has to be fitted with the correct propeller or get an engineer order to fit something different. Nowadays RAAus is no different. Same same just different words.
BrendAn Posted December 12 Posted December 12 2 hours ago, skippydiesel said: Agree with the inference made by Blue. As the builder, you can put a V8 & a dometic fan blade on the front if you wish - it may not pass its safety inspection or get off the ground but those are two other matters/hurdles. People have crafted their own prop - how did they manage to be aproned????😈 i think you will find that has changed now. everything has got harder the last 12 months with raas. the mt beaty court case has ruffled a lot of feathers. i have registered 2 19 category planes recently and i had to supply information on engine and prop. had a hell of a time getting a 582 powered xair transferred because it had a sweetapple fitted but had a brolga when first registered. they accepted it eventually but it took 2 weeks.
danny_galaga Posted December 12 Author Posted December 12 26 minutes ago, Thruster88 said: As you would know, the DH 82 tiger has to be fitted with the correct propeller or get an engineer order to fit something different. Nowadays RAAus is no different. Same same just different words. You'll notice on their website that P Prop have in fact supplied props for Tiger Moths ☺️ 1
Thruster88 Posted December 12 Posted December 12 13 minutes ago, danny_galaga said: You'll notice on their website that P Prop have in fact supplied props for Tiger Moths ☺️ The engineering order for the tiger probably cost as much as the prop, that is what people get miffed about. 1
facthunter Posted December 12 Posted December 12 It's BS anyhow. Wood laminated and done properly have no bad surprises and are easy on the motor. In theory I could design and build a complete motor for the right category. Nev
skippydiesel Posted December 20 Posted December 20 On 12/12/2024 at 6:39 PM, BrendAn said: i think you will find that has changed now. everything has got harder the last 12 months with raas. the mt beaty court case has ruffled a lot of feathers. i have registered 2 19 category planes recently and i had to supply information on engine and prop. had a hell of a time getting a 582 powered xair transferred because it had a sweetapple fitted but had a brolga when first registered. they accepted it eventually but it took 2 weeks. May be. When I registered my 19, late 2022, Aircraft varies significantly from factory plans. I supplied everything asked for, which included prop make/model, instrument calibration/certification, independent inspection/comments, W&B, test performance data and Max TO weight, etc, etc. I used the factory recommended Max TO Wt. Found out later, as builder, I could have nominated whatever Wt I chose. Contacted factory requesting approval for one off higher TO Wt, with reasoning- flat refusal. Months later factory upped Max TO Wt (to meet new US guidelines for class of aircraft) with no structural changes. Applied to RAA for Wt increase - told my prerogative as builder - send in photo of revised panel placard - done & approved. So much for all that BS about home builder having to stick rigidly to factory plans/specs. 😈 1
facthunter Posted December 20 Posted December 20 At the end of the day there has to be SOME form of oversight as always its for the Lowest performing cowboys or whatever that ruins it for everyone.. People are fundamentally lazy and cut corners when not watched. She'll be right Mate, is alive and well. That's OK if it only affects YOU. but it's not like that. It's a culture , safety and IF the show doesn't have it you will eventually "draw the Crabs". Nev
danny_galaga Posted December 20 Author Posted December 20 Agree on the oversight. But verifying the veracity of my propeller is one google search away...
facthunter Posted December 20 Posted December 20 Google has veracity? IF only it were so.. Fools abound and they are good at it.. Beware of them. They cause all of us, Grief. Nev 1
danny_galaga Posted December 20 Author Posted December 20 Um, what I mean is if someone is wondering about the veracity of my propeller, they need only type the brand into Google and find the website 1
danny_galaga Posted December 20 Author Posted December 20 2 hours ago, facthunter said: We must live in different worlds. nev I guess so. I live in the world that if I want to find something out about a manufacturer, I can type their info into Google and find their webpage, and find something out about that manufacturer 🤷♂️ 1
onetrack Posted December 20 Posted December 20 (edited) You just have to be careful about what Google throws up for search results. Scammers set up fake websites to scam people, and then "game" Google search algorithms to end up high in Google search results. A recent example is the legit-looking site recently exposed, that claimed to provide heaps of great information about upcoming welfare payments. But the payments are non-existent. However, the information provided is about legit earlier welfare payments - the scammers just make it appear the payments are going to be repeated. I think I'm reasonably savvy, but the fake "information" site took me in. However, after close reading of the "information", it became obvious to me there was something about it that didn't jell. The style of writing was poor. I suspected it was written by AI, but I didn't realise scammers do this setting up of "information" sites regularly, to set up unsuspecting people up, same as any other sting. Incidentally, if you come across a fake website (there's plenty out there, watch out for the ones selling bargain aircraft parts!), you can report them to Google, and Google will delete them from search results. Of course, this doesn't stop the scammers from just changing something about the fake site, and then getting back into Google search results again, though. It's a "whack a mole" game, just like trying to block scam phone calls. Google Safe Browsing: Report a Malware Page WWW.GOOGLE.COM The lucrative scam business behind a non-existent Centrelink payment - ABC News WWW.ABC.NET.AU These websites might seem like victimless enterprises, but there are real-world consequences for people who get tangled up in the lies. Edited December 20 by onetrack
BrendAn Posted December 20 Posted December 20 18 hours ago, skippydiesel said: May be. When I registered my 19, late 2022, Aircraft varies significantly from factory plans. I supplied everything asked for, which included prop make/model, instrument calibration/certification, independent inspection/comments, W&B, test performance data and Max TO weight, etc, etc. I used the factory recommended Max TO Wt. Found out later, as builder, I could have nominated whatever Wt I chose. Contacted factory requesting approval for one off higher TO Wt, with reasoning- flat refusal. Months later factory upped Max TO Wt (to meet new US guidelines for class of aircraft) with no structural changes. Applied to RAA for Wt increase - told my prerogative as builder - send in photo of revised panel placard - done & approved. So much for all that BS about home builder having to stick rigidly to factory plans/specs. 😈 That was 2022. Ths year things have changed. Raas are going over everything with a fine tooth comb these days. There are inconsistencies too. Forcing people to get casa weight and balance checks at a cost of up to $1000 . My 2 xairs they dropped one to 450.kg from 544 and the other to 490 because I said I wasn't happy with 450. There is a bloke on Facebook who was made to get a w&b for a trike at a cost of $835, it was a standard Aus brand trike with no mods at all, been regoed with safa for 20 yrs but raaus forced the issue as part of the transfer. A vh plane can go it's whole life without a w&b if it's not modified.
BrendAn Posted December 20 Posted December 20 9 hours ago, facthunter said: We must live in different worlds. nev Why. All the main manufacturers have a website with all the information you need.. it's 2024 nev not 1955 1
turboplanner Posted December 20 Posted December 20 11 minutes ago, BrendAn said: A vh plane can go it's whole life without a w&b if it's not modified. That's because the manufacturer has provided a certified dry W&B for the aircraft to FAA/CASA etc. From that comes the envelope version of the same set of equations. Qualified Engineers need to be paid. The going rate for a minor wheelbase change certification for a truck is currently around $1100.00
skippydiesel Posted December 20 Posted December 20 3 hours ago, BrendAn said: That was 2022. Ths year things have changed. Raas are going over everything with a fine tooth comb these days. There are inconsistencies too. Forcing people to get casa weight and balance checks at a cost of up to $1000 . My 2 xairs they dropped one to 450.kg from 544 and the other to 490 because I said I wasn't happy with 450. There is a bloke on Facebook who was made to get a w&b for a trike at a cost of $835, it was a standard Aus brand trike with no mods at all, been regoed with safa for 20 yrs but raaus forced the issue as part of the transfer. A vh plane can go it's whole life without a w&b if it's not modified. The Max TO weight increase, was just a month or so ago. I can't comment on why RAA would impose changes to existing TO wt. As for Certified W&B. It would seem that RAA had its authority, to approve W&B, removed for some reason. This meant that anyone requiring a W&B, had to go the CASA/Certified rout, including me. I shopped around and found a Certified service provider, at a considerably better price (almost 1/2) than what you have quoted. 1
