  On 02/01/2025 at 2:59 AM, BrendAn said:
i think nev has hit the nail on the head. simple is best. a cable or rod is nearly foolproof and you don't have to wonder if your chinese electrics are going to fail.
My friend, is it possible, that you did not read the proceeding comments, from me?
The traditional system(s) of Cole Flap actuation, present a series of chalanages, I do not wish to address.
The electrical solution, long since adopted in the automotive world , is my proffered concept.
The concept has been tested - It works! -  fact!
Unfortunatly I have yet to find a suitably robust Linear Actuator of the correct specifications, that will give a durable service - this is why I asked the question in my opening comments.
So I ask you again -Are you able to recomend a supplier of quality linear actuators that may suit my purpose??😈
Skippy, have you tried the company listed below? Despite your (and my) abhorrence of Chinese-made parts and components, it's becoming extremely difficult to find anything that is not manufactured there now.
I've tried in vain recently to acquire bearings that are not made in China, and despite buying "quality, brand names" (including the finest Japanese and European bearing names), I've continually been upset to open the "quality" box, and find "Made in China" stamped on the bearing!!  They have won the manufacturing war by sheer volume, by constant "competitive" pricing, and by being able to supply parts/components rapidly, in vast numbers.
The car industry is next. Chinese cars will dominate the world within 5 years, I reckon. I read where BYD have 1,000,000 employees, and 110,000 engineers!! FFS, why would anyone even try to compete??
WWW.MOTIONDYNAMICS.COM.AU
Explore our premium range of Linear Actuators (12V-24V), offering high performance with force capacities from 200N to 7000N and strokes from 100mm to 500mm (IP65 rated). Comparable to top global brands...
Edited by onetrack
I did read your comments. I think its Much better to keep it simple.  No I don't know where to get a quality actuator.
Correction: I am great admirer of the Chinese and their work philosophy. Industrially, scientifically & possibly militarily we have much to be concerned about - they are consigning us (the West) to history.
In my lifetime I have seen the rise & rise of Asian industry.  Look at the high quality products from the Japanese & Koreans - in my youth much sneered at. The Chinese & Indians have put rockets/satellites into space. Sure they give the World cheap low quality products but they can & do, deliver as high a quality as we are willing to pay for.
Thanks for the WWW.MOTIONDYNAMICS.COM.AU - I have written to them asking for their recommendation - Unfortunatly my browsing of their website, suggest even their smallest actuator is likly many times the weight/size of what I would like.😈
You are over complicating a non  existent problem. There's practically NO load  involved and you can feel if it's Jammed and increment the adjustment. Same with Flaps Best Hand operated where if there's a need for change it's quick. With NO assymetry protection, powered flap is a risk. YOU don't NEED this $#!t And it goes On and On with you paying no heed to what others say, by and large.. Why bring it up here IF you are already convinced? Nev
  • Sad 1
Hi onetrack. This is the smallest 25 mm LA that MOTIONDYNAMICS have on their web page:
Dimensions
This is dimensional idea (not the actual unit) of what I am after:
Electric Micro Linear Actuator 12V 21mm 30mm 50mm 75mm 100mm Stroke UpTo 150mm/s - Picture 28 of 44
  On 01/01/2025 at 10:58 PM, Marty_d said:
There was an interesting cowl flap shown somewhere here, French bloke had it on top of his cowl to release heat while on the ground.
From memory it was hinged forward of the midpoint of the flap and lightly sprung, so at low speeds it would open but any wind pressure would close it.
This'd be the post you're referring to, Marty.  As you say (and AFAIK) the device is only meant to reduce heat soak under the cowl on the ground.
Skippy, you're obviously looking for a micro linear actuator, as compared to a regular size industrial linear actuator. AFAIK, the major manufacturers/suppliers of micro linear actuators, are those people in the RC controls industry.
As a last resort, you could try RS Components. They will supply nearly anything electrical (and promptly), but usually at aircraft-parts-style pricing. The major advantage of RS Components is their website is very good, and you can select all types of technical product criteria in your part search - such as stroke, threads, lengths, voltages, loads, etc, etc - to go pretty accurately to the product you're looking for.
RS sell micro linear actuators from a company called Actuonix Motion Devices, who are Canadian, and who were once part of Firgelli, before they decided to operate as a stand-alone company.
AU.RS-ONLINE.COM
Browse our Electric Linear Actuators offer. Place your order today for our Electric Linear Actuators.
Skip you are going to have to put some numbers on the requirement.
Force - I cannot beleive much unless it is acting as a bucket scoop ,But it WILL have some of the pressure of the cowl insides... You would be able to make a reasonable estimate of the upper limit of the pressure on the cowl flap.
Travel ? .
Many Model RC-servos will do the job you want , since I gather you are fine if it doesnt work.
The data sheet for a typical 20mm stroke Actuinox Motion Device linear actuator, is linked to, below. Note that the "maximum duty cycle" is only 20%, and they also note that "repeated stalling of the actuator against a fixed load will shorten the life of the actuator".
This indicates to me that the micro linear actuators are not really "industrial grade", nor really suitable for full-size aircraft use, where you'd normally expect a substantial degree of durability and reliability.
https://docs.rs-online.com/f045/0900766b814ad9d3.pdf
I do not understand.
The LA's I have been using have two wires.
Switch down - current drives motor - system extends -  "hits" stroke limiter and cuts off current.
Switch Up - current reverses motor - system retracts - "hits" stroke limiter and cuts off current.
Note: There is no need for an interim position ie its either fully open or fully closed
The above system can not repeatedly stall, as stroke limiters shut of current/drive at the end of each stroke movement.
The stall will occur if the actuator can’t reach the limit switch for some reason (eg too much load).
Travel ? .
I don't follow.
I have been using LA's with a claimed 19kg extension force - many times what might be required to open a small flap, to say 30-45 degrees.
The pressure, on the closed flap is minimal, as its function is a "choke' or restriction, not shutting of the air flow completely.
The lower closing force of the LA is equally of no concern, as the air pressure against the flap will assist the retraction.
The LA's, for their short life, have worked well.
As earlier mentioned - a post-mortem of the first LA found that the motor still ran, the extension/retraction system still worked, however the stroke limiter circuit had failed, thus not allowing the reverse of current polarity to retract the system.
The following are the specifications I have been working to:
·         Some resistance to moisture, dust & temperature. The actuator may be inadvertently exposed to water, during cleaning and in operation, air temperatures to 600C.
·         Extension range 20-25mm.
·         Working speed 5-10mm/sec (negotiable)
·         Thrust 20kg (negotiable)
·         Installed length (retracted) 75 -80 mm
·         Fully extended/retracted, built in, electronic limit switches (existing remote switch to reverse polarity/direction of movement)
·         No power “lock” in fully extended/retracted position.
·         Constructed of corrosion & vibration resistant materials
·         Current mountings 4mm ID both ends but could be modified.
·         Automotive standard 12V electrical cable
The extension of 20-25 mm, will give an approximate 45 degree flap movement.😈
Edited by skippydiesel
There is no description of the flap your moving. Maybe it’s pressed up hard in its track that then act as a break. You need to provide more info and image of what’s not working.
Edited by Blueadventures
Cowl flap is the full width of & conforms with, the shape of, the underside of my cowling and aproximately 150 mm wide. Hinged at the afte edge of the cowling (no possibility of jamming).
When closed, conforms with/looks like, an extension of cowling bottom.
When open, goes to about 45 degrees down,
Will try & find a photo
It would seem that a compact/small linear actuator,  with proven reliability, does not exist.
There are much larger/heavier units available but then there are questions of space to fit and weight to consider, along with changes to existing bracket, shape, size/location.
There have been not so subtle suggestions that I should avoid Chinese suppliers - FYI I have yet to find a single  supplier who does not have his LA's made in China.
I think I will fall back to a very simple system, that I have used on another aircraft to good effect - a winter & summer fixed flap. This will likely be a single flap with removable/replaceable air flow "chokes"  ie more "choke" for winter less/0 for summer opps.
Somewhere "down the track" a suitable LA may come on the market.😈
Hi Skippy, I have used many many  hundreds of linear actuators over the past 60+yrs I’ve been involved with automatic gates etc; Hydraulic used to be the be all and end all of systems, but not now for reliability. They all without exception have certain drawbacks. Not saying ALL Chinese stuff is crap, but so much on offer is and suppliers don’t keep spares spares for the long term. If you can find an alternative solution on the basis of simplicity being the essesnse is reliability i’d be going along that path. For the past 45yrs or so I’ve used Italian stuff for very good reason whether it be domestic doors or aircraft hanger doors. Simplicity for whatever reason is the go for me. Good luck mate with your decisions whatever they turn out to be. Might even catch up with you at The Oaks someday, that would be nice. Been a decade or 2. Rgds Planey.
Hi Planey,
Thank you for your kind & encouraging words.
It seems to me that small/compact LA's would have many applications in small experimental aircraft, however this will not happen until they can be made reliable - a few hours of operation (cycles) before giving up the ghost,  is not reliable.
The reason for my optimise is simple - I find running electrical cables far easier than trying to do the same thing with the traditional levers & pull push cables.😈
An electrical system requires an intricate series of design checks.   Does actuator require stalled motor overload,  fuses and circuit breakers are to protect the cabling? Is reversing done by the actuator or external reverse polarity, limit switches may just be to reduce stalled load, what if actuator stalled to some overload?  What is the actual current taken during operation online under load?  I had an actuator, screw type) failure by losing a tooth owing to a loose mounting bolt and stiffer than normal load, impact caused it.  Do you know the actual load on the actuator in flight?  I know that opening a door beyond ajar at 160kt is beyond my strength.
  • Winner 2
We're flogging a dead horse here. Fairly large flaps are operated Manually and if you have a cowl flap (which is a good idea from engine management and drag advantages) why not make it adjustable in flight over the whole range?   Nev
The way I see it if you want something for whatever reason go for it!
Skippy my actuator was in part a function of using clevis ends. I prefer rod end bearings,  misalignment can cause loads owing to friction, rod ends ensure minimum spurious loads.
