eightyknots Posted September 15, 2010 Posted September 15, 2010 Does anyone know whether Storch sells the onboard fuel pump set-up for use in other planes? It sounds like a great idea for all light high-wing planes :-) Perhaps Pipistrel sells them as an aftermarket product?
Guest Walter Buschor Posted September 15, 2010 Posted September 15, 2010 Like most I just stand on a ladder and hold the can whilst grunting over the weight of the fuel. I remember seeing some very expensive collapsible concertina type "jerry cans" . They could be used with an appropriate adaptor. Idea being that you simply stand on the thing whilst holding the "adaptor , hose, nozzle" and remove your foot when finished. Perhaps worth a try for someone wanting to spend upwards of $400 on it. I just keep putting up with my leaking and crossthreading red rubbish cans and eat my weetbix. fly safe Walter
jetjr Posted September 15, 2010 Posted September 15, 2010 Tanami Pumps | Tanami Pro | Canning | Birdsville | Eyre | Pilbara | Wilcannia | Fraser These are used in off road situations, they often have small air comp on board. No reason they wouldnt work with hand or foot pump.
eightyknots Posted September 16, 2010 Posted September 16, 2010 Saw a member of our club last weekend refuelling his Cub Savage. He was using the "old style" metal Jerry can with Earth wire/clamp attached & he had made up a setup for the opening of the jerry can which he connected a very small 12v air compressor to which he powered off a small dry cell battery. He just left the jerry can sitting on the ground & put the hose in the tank with the air pressure pushing the fuel up the hose. I hope that the motor has some kind of spark shielding around it.
eightyknots Posted December 11, 2012 Posted December 11, 2012 Does anyone know whether Storch sells the onboard fuel pump set-up for use in other planes? It sounds like a great idea for all light high-wing planes :-)Perhaps Pipistrel sells them as an aftermarket product? I wonder if they do?
hihosland Posted December 11, 2012 Posted December 11, 2012 For a while I used a LiLo foot pump to pressurise a Jerry can with air and force the fuel up into the aircraft. I gave that idea away when thinking that should a spark occur from static or other event a pressurised fuel/air mixture becomes an instant bomb/flame thrower. Without the injection of air the vapour in a Jerry can is probably too rich to explode. I feel that the potential hazard with pressurised fuel/air mixtures just too high to continue using such systems. So back to the step ladder and jerry can Davidh 1
eightyknots Posted December 11, 2012 Posted December 11, 2012 I gave that idea away when thinking that should a spark occur from static or other event a pressurised fuel/air mixture becomes an instant bomb/flame thrower.
