red750 Posted February 8 Posted February 8 Cirrus Tells Owners Not To Use Unleaded Fuel WWW.AVWEB.COM Cirrus is concerned G100UL may cause structural damage to its airplanes.
spacesailor Posted February 8 Posted February 8 (edited) What is " G100 " I understand " UL " but , nowhere can I find ' mogas 100 UL fuel '. I like others have to use ' AVgas 100 LL ' or 98 super petrol ( mogas ) . spacesailor PS. : any fuel spilt onto " composite " aircraft , would be a worry . Keep it in the fuel tank . Edited February 8 by spacesailor PS added
Arron25 Posted February 9 Posted February 9 (edited) 4 hours ago, spacesailor said: What is " G100 " G100UL high octane unleaded avgas G100UL.COM Find out more about GAMI's G100UL® high octane unleaded aviation gasoline. Website addresses the Cirrus Notification specially... Edited February 9 by Arron25
facthunter Posted February 9 Posted February 9 That Mob GAMI in USA are trying to produce a new fuel to replace 100LL which for sure will be discontinued someday. Nev
spacesailor Posted February 9 Posted February 9 All the fast cars use Alcohol. ( 500 klmtrs p h) Water is the fire suppressant. spaesailor
Thruster88 Posted February 9 Posted February 9 (edited) 4 hours ago, facthunter said: That Mob GAMI in USA are trying to produce a new fuel to replace 100LL which for sure will be discontinued someday. Nev Cross out "are trying to produce" and replace it with HAVE PRODUCED. Impediments to this, Lawyers, vested interests, useless government. Edited February 9 by Thruster88 1
KRviator Posted February 9 Posted February 9 5 hours ago, spacesailor said: All the fast cars use Alcohol. ( 500 klmtrs p h) Water is the fire suppressant. spaesailor Not with 1500-2000 hours between overhauls they don't!
kgwilson Posted February 11 Posted February 11 There is no problem with the fuel itself as Cirrus approved it originally & anyway it is used in lycoming engines. After doing the latest check which noted some paint damage around the drainage sump of a single Cirrus, this was confirmed as a maintenance issue and there were no safety of flight issues. A G100 developer employee and Cirrus owner has been using the fuel for 15 years with no engine or paint issues. It all sounds like an attempt to get some money out of GAMI with the Cirrus owner failing to wipe off spilt fuel. 2
