skippydiesel Posted Monday at 12:31 AM Posted Monday at 12:31 AM Having a bad trot with my ADAHRS. Wondering if anyone else in Au experiencing similar. Original (first) module worked perfectly for aproximately 130 hrs Failed without warning, on ground, on pre engine start check. Cable continuity checked and found to be good. Loan module worked perfectly for about 5 hrs - Replaced, still working, when new (not remanufactured) module arrived. No explanation from Dynon as to reason for OM failure. New module had initial problems (frozen compass) - Fixed by belated download/update New module worked faultlessly for about 4 hrs New module failed on ground, on pre engine start check. Dynon sending a loaner module, hope to install today Note: First module failure , turned whole electrical system off several times - red cross & failure message appeared each time Second module failure, as above, however each time normal screen appears but only remains for about 30 seconds, before reverting to red cross & failure message. 😈
rodgerc Posted Monday at 12:43 AM Posted Monday at 12:43 AM Might be worth chatting to David Brown in Brisbane. david at candoitaustralia dot com dot au
skippydiesel Posted Monday at 01:04 AM Author Posted Monday at 01:04 AM (edited) Thanks Rodgerc - have emailed him😈 Edited Monday at 01:07 AM by skippydiesel
skippydiesel Posted Monday at 04:10 AM Author Posted Monday at 04:10 AM 3 hours ago, rodgerc said: Might be worth chatting to David Brown in Brisbane. david at candoitaustralia dot com dot au Email address not good - got another?😈
KRviator Posted Monday at 05:31 AM Posted Monday at 05:31 AM What's the failure message? That "Multiple Sensors failed" type thing can often be caused by attempting to do a pitot-static check without being in test mode, the ADAHRS sees the rapid climb/descent and IAS changes without corresponding GPS position or accelerometer changes and cries foul. Doesn't sound like you've actually done a P-S test, but it might be somewhere to start. First thing I'd do is unplug your GPS antenna, do a network calibration to rediscover all the modules but without the GPS, cycle power and see what happens. 1
rodgerc Posted Monday at 08:02 AM Posted Monday at 08:02 AM 3 hours ago, skippydiesel said: Email address not good - got another?😈 Sent you a message
skippydiesel Posted yesterday at 01:01 AM Author Posted yesterday at 01:01 AM Had a great chat with David Brown - certainly knows his Dynon (& other) systems inside out.😈 1 1
skippydiesel Posted 5 hours ago Author Posted 5 hours ago Latest ADAHRS fitted - off to the airfield to do the compass calibrations. 1
