skippydiesel Posted yesterday at 08:07 AM Posted yesterday at 08:07 AM Sonex aircraft, Rotax 912 ULS, plumed fairly conventionally. Rotax mechanical diaphragm pump 150 hrs. Facet Boost pump with bypass circuit (includes non return valve) This might test out the brains trust. Usually in Cruise, sometimes on Descent I get a low fuel pressure warning. On occasion, indication as low as 1.5 psi. No change in engine note/performance. Sometimes it corrects itself over a few minutes , other times I switch on the Boost pump for immediate fix. Note: I have already mounted the fuel sensor as high as I can within the engine bay, removed the silicon seal to facilitate changes in atmospheric pressure and drained the fuel pressure line. On the way home from Holbrook, the low fuel pressure warning sounded and pressure dropped to 1.5 psi, well below the Rotax 912 ULS minimum of 2 psi and the usually 4-5 psi. I then noticed, the Fuel Flow had risen from 15 L/hr to 25 L/hr. At this point I switched on my fuel Boost pump - immediate rise to 5 psi AND the Fuel Flow dropped back to 15L/hr - switched off the pump and pressure/flow remained where expected. The same scenario happened again a little later. To me drop in pressure combined with a rise in flow is counterintuitive. This may happen with a garden hose but not a closed fuel system. What might the Brains Trust think is happening. 1
Red Posted yesterday at 08:46 AM Posted yesterday at 08:46 AM Is this all from readings on that Dynon you've been having problems with? 1
Red Posted yesterday at 08:48 AM Posted yesterday at 08:48 AM (edited) Quote To me drop in pressure combined with a rise in flow is counterintuitive. This may happen with a garden hose but not a closed fuel system. Not really, it would happen in certain situations like a leak downstream But that wouldnt explain what happened when you switched on the Boost Pump, Id be suspicious that this is all false readings Edited yesterday at 08:50 AM by Red
skippydiesel Posted yesterday at 10:17 AM Author Posted yesterday at 10:17 AM Almost certainly false readings - but how & why? Yes its the Dynon Skyview ADAHRS (Air Data/Attitude/Heading Reference System) system that has been playing up. The fuel pressure is part of the EMS (Engine Management System). Mind you both systems are "read"/displayed by the SE SV/D600 screen.😈 1
Moneybox Posted yesterday at 10:18 AM Posted yesterday at 10:18 AM Skippy, where is your fuel flow measurement coming from? It sounds like there is an intermittent bypass there allowing more fuel to return to the tank. What in the system would usually limit that return flow? 1
skippydiesel Posted yesterday at 10:34 AM Author Posted yesterday at 10:34 AM 2 minutes ago, Moneybox said: Skippy, where is your fuel flow measurement coming from? It sounds like there is an intermittent bypass there allowing more fuel to return to the tank. What in the system would usually limit that return flow? I agree with your logic but unfortunately not with its application. Fuel flow data is from two Red Cubes (fuel flow sensors). One on the main delivery line between mechanical pump & carburettors and one on the return to tank line. The return line Cube data is subtracted from the main line Cubes data to give fuel used/fuel remain information to the pilot. There is also a fuel flow readout, that helps in engine power setting. Fuel pressure is registered by a sensor, located at the end of dedicated line, coming of the fuel distributor. The distributer, takes fuel from the pump, delivers fuel to each carburettor, the tank return and the deadened (no flow) pressure sensor line. The return line has a fixed restrictor jet. As far as I can see there is no opportunity for an increased flow, other than opening the carburettor throttles (higher consumption).😈 2
Thruster88 Posted 22 hours ago Posted 22 hours ago One possible cause, the engine pump has an intermittent fault in the inlet valve. When the valve acts up the pressure naturally drops. The increase in indicated fuel flow is due to fuel pulsing back and forth in the flow meter. If the flow meter is after the engine pump then the outlet valve could do this. Any time the boost pump is turned on in steady cruise flight the fuel flow INDICATION dramatically rises in my RV6a, has to be due to fuel pulsing. Fuel will pulse with a faulty valve. 1
skippydiesel Posted 21 hours ago Author Posted 21 hours ago Thanks Thruster - The difference in indication between your RV & my Sonex is - Boost pump on, fuel flow reduces/goes down. The opposite of your indication.😈
Thruster88 Posted 21 hours ago Posted 21 hours ago 3 minutes ago, skippydiesel said: Thanks Thruster - The difference in indication between your RV & my Sonex is - Boost pump on, fuel flow reduces/goes down. The opposite of your indication.😈 In your case the boost pump is possibly restoring a smooth fuel flow, masking a fault in the engine pump if that makes sense. 1
skippydiesel Posted 20 hours ago Author Posted 20 hours ago Rotax Owners Forum - suggestion it may be due to fuel vaporisation ?😈
IBob Posted 13 hours ago Posted 13 hours ago I return to my original suggestion: You have either periodic loss of fuel pressure, or periodic incorrect fuel pressure sensing. I would find out which by temporarily fitting a steam gauge. That cuts the problem neatly in half and points you to where to start looking: instrumentation or fuel system. 3
facthunter Posted 11 hours ago Posted 11 hours ago I go along with the Rotax forum suggestion.. Your bleed orifice could also flow too much. Your engine Pump doesn't handle it. . Nev
