kfowler Posted June 8, 2008 Posted June 8, 2008 can anyone tell what sort of load you would get going from a 60 x 42 to a 56 x 44
jetboy Posted June 10, 2008 Posted June 10, 2008 Rule of thumb for changing prop dia; every inch of dia change should be matched with 2 inch inverse to the pitch. For your decrease of dia by 4" you should be looking at increasing pitch to 50" note your thrust efficiency will also drop around 5% to answer the question directly, the load will be lower with the quoted smaller prop. Ralph
kfowler Posted June 10, 2008 Author Posted June 10, 2008 thank you for spending the time to answer my question. very help full thank you:clap:
