jetjr Posted August 20, 2008 Posted August 20, 2008 HEI ignition kit wont fix the no cranking problem. That means solonoid stuffed or starter isnt getting power By the sound of the clicking noise thats the solonoid not getting full power or its stuffed
jetjr Posted August 20, 2008 Posted August 20, 2008 Something like this?? www.aircraftspruce.com/catalog/eppages/slickstart.php JR
Ultralights Posted August 22, 2008 Posted August 22, 2008 Our Jab at Hoxton park used to have the same problem, now it has new heads, and new Alternator, and she starts first time every time, even in sub zero temps! just full choke, carby heat, and off she goes!
quentas Posted September 3, 2008 Posted September 3, 2008 I installed a new Deka battery in my 230 and I cant believe the difference! It fires almost instantly as the battery has heaps of grunt. I got one on the advice of several Jab owners on the eyre pen and they swear by them. They are slightly bigger than the Odysey though.
jetboy Posted September 14, 2008 Posted September 14, 2008 Motzartmerv you alluded to a factory test of a new ignition please tell all.... I note that one of the guys in the US is fitting a separate system and not havung any distributors on his rebuild (from a failed crank drivegear problem) I've not had any trouble with the lawnmower coils to date except the low battery/no start issue - recently swapped out my oldish Odyssey PC925 (actually the Genesis version, same specs) for a better one and normal starting has resumed The other reply mentioned Deka battery are these a house brand of something at Supercheep or k mart? and what type of batt. is it - sealed AGM? Ralph
Guest Bendorn Posted September 17, 2008 Posted September 17, 2008 Very Simple I did post this yonks ago..... The common problem with cold mornings is to do with earthing. All you have to do is move the earth from its current position on the back to the front and add a extra washer which will fix it. No bigger batteries needed. No pouring hot water. Ring Cliff Banks at Swan Hill and he'll tell you exactly how it is done. It will take minutes to rectify and less than $2.00. I kid you not it is that simple. :thumb_up:
Ross Posted September 17, 2008 Posted September 17, 2008 get more earth For detail see the service letter on the Jabiru website http://www.jabiru.net.au/Service%20Bulletins/Engine%20files/Starter%20Motor%20earth%20Cable_JSL005-1.pdf It might also pay to check the gap between the permanent magnets on the flywheel and the coil which according to my construction book should range from 0.010" to 0.012" or 0.25 mm to 0.30 mm.
Guest Bendorn Posted September 18, 2008 Posted September 18, 2008 That's the one Ross.....!!!!! Simple.:big_grin:
Guest brentc Posted September 18, 2008 Posted September 18, 2008 I'll change mine on the weekend and report back. I'll know straight away if it makes a difference.
Guest Bendorn Posted September 27, 2008 Posted September 27, 2008 I'll change mine on the weekend and report back. I'll know straight away if it makes a difference. How did you get on?
Guest brentc Posted September 27, 2008 Posted September 27, 2008 My engine is cranking MUCH faster today. On a hot start today I was quite surprised. It sprang to life in a split second!
Guest Bendorn Posted September 27, 2008 Posted September 27, 2008 Great stuff. Spread the word...... ;)
