Turbo_Boss Posted July 1, 2008 Posted July 1, 2008 Hello Guys, I need to replace the Rotary Valve hoses that goes to the small tank reservoir. One of them has a crack and eaven that is no leaking, I want to replace both. One RV hose run on the back of the magnetos plate and I have to remove that plate/bracket in order to have access to the clamp were is atached. That plate/bracket is attached to the engine by four screws............ Two of does upper screws also hold the water outlet socket in his place so I will be carefull when removing does 2 screws. So here are the questions: Do the 2 remaining lower plate/bracket screws hold something else that the Magnetos plate? Or I just go ahead and remove them. Any advise on doing this work? Do I need to remove something else to have access to that clamp/hose? BTW, this Rotax 582 is a grey head, is top mounted on a Quicksilver UL and the spark plugs are facing up. Thx for your time and help, Isaac
Guest rocketman Posted July 5, 2008 Posted July 5, 2008 Hey Turbo,Be careful with the 4 bolts that attach the timing plate. 2 are longer than the others. Put them back in the wrong place and you can break the lugs on the casing. If you have already removed them, use a depth gauge to work out which bolt goes where. How's the flying in Panama?Neale.
Turbo_Boss Posted July 7, 2008 Author Posted July 7, 2008 Hey Turbo,Be careful with the 4 bolts that attach the timing plate. 2 are longer than the others. Put them back in the wrong place and you can break the lugs on the casing. If you have already removed them, use a depth gauge to work out which bolt goes where. How's the flying in Panama?Neale. Hello Neale, I am talking about this plate. The two upper bolts are diferent that the ones on the bottom. Isaac
