sometmes the oil gets very hot, orange zone, oil pressure drops to minimum.
no possibility to cool it down in flight.
motor has 450 hours governor johostroj and alisport porpeller (constant speed)
happens mostly after a short climb or sharp turn, oil temperature is climbing in a few seconds from beginning green zone to the orange zone.
have someone same troubles? all ideas tofind the rootcase are wellcome.
thanks from Belgium
Guest pelorus32
G'day phvdw,
what sort of aircraft? Sometimes the installation gives a clue.
Also is that an electric CS prop.
Regards
Mike
g'day Mike,
Type of aircraft Impulse, constant speed propellor with oil pressure
picture of plane under my login
KR
Guest pelorus32
G'day,
I don't know the answer here but here are some thoughts:
Is the constant speed unit hogging oil at points where it has to go fine - a climb or a sharp turn?
Does the Rotax have a pressure bypass valve of some sort? It sounds like the oil flow is being disrupted.
Let's wait for some of the guys who know what they are talking about to chime in here.
Regards
Mike
  • 7 months later...
problem solved; oil return wrong installed; 2 possibilities for rotax; push option was installed changed in pull and flew now for 20 hours without a problem, waiting summertime to see end result
