Fitted the new Sensenish 62" X 56" prop today.
Climb: Better requires further testing.
Cruise: 124KN @ 1500ft. 14C; F/F 22.5 lt/hr @ 2800rpm; Oil temp 85; CHT 250F;
EGT 700C .
Max Pwr: 140kn. 3100rpm. 34lt/hr.
Smoother, much better than dynamically balance previous prop.
Jabiru LSA approved for all except J160. $Cost: $1400 Aus from Jabiru ex Bundy.
:thumb_up::thumb_up::thumb_up:
This new prop,What aircraft was this trialed on? Is it approved For their new J120?
Yes I seen the first of these at my last visit to Jabiru. These were a hardwood prop as apposed to the softwood used by Jabiur and they were slightly modifying the pitch at the time and waiting for a new batch to arrive from the US. I gather this is that batch? Is it fitted to the J230C/D LSA? What was your climb?
Sorry still recoverying from Oshkosh trip!
Mine's a J230D, the T/O weight was 570KG.
Rod said all but the J160. Don't know if it has trialled on the J120.
I always climb out after clean up at 80 - 90 Kn so hard to say.
If you want to go for climb go for the 53" pitch. You'll get 1000'+ a min. Will get to 140KN OK but overspeeds I'm told. (3400rpm)
