Guest Peggy2 Posted September 14, 2008 Posted September 14, 2008 I recently changed over to RaAus from HGFA and when removing the old numbers from the wing of my trike the glue stayed put. Wingtech advised me to use Metho on it but this didn't work, neither did petrol. The old rego numbers were about thirteen years old before I removed them so the glue has had plenty of time to cure. Does anyone know of something that will soften the glue so it can be scraped off without damaging the fabric or colour? Thanks.
wanabigaplane Posted September 14, 2008 Posted September 14, 2008 on the terps I have found old adhesive is more easily removed with turpentine than metho, petrol, or orange cleaner. It is even more effective if allowed to soak a bit. However; I have no idea what it does to fabric, so try a small area first ! Jack. :):)
Dieselten Posted September 14, 2008 Posted September 14, 2008 Xylene. It is a carcinogen (right up there with Benzene) but it will do the job.
Arnaud Posted September 14, 2008 Posted September 14, 2008 We regularly use WD40 to remove stuborn stickers. There is a HUGE list of uses on their website where we found the info. Personally I'm scared, not of flying but of xylene, benzene, hexane,etc... I think it is right up there with asbestos, the silent killers.
Steve L Posted September 14, 2008 Posted September 14, 2008 Hi Peggy, Try Citra Clean, its a natural citrus product and is available from tile supplies stores. We use vinyl stickers all the time in our business and need to remove the old daggy ones regularly and it does get off the old glue. You might have to use a bit of elbow grease but it will get the residue off. Steve
facthunter Posted September 14, 2008 Posted September 14, 2008 Stuck stickers. Preparations containing eucalyptus oil can be helpful. Sometimes a bit of heat, like a hair dryer will do the trick too. Nev
jcamp Posted September 15, 2008 Posted September 15, 2008 Personally I'm scared, not of flying but of xylene, benzene, hexane,etc...[/Quote] Better take up gliding to avoid petrol.
Guest ozzie Posted September 15, 2008 Posted September 15, 2008 Try a natrual product called citrasolve to remove the glue. it won't kill you in 20 years time.Similar to the above. I also have had great success in removing tape, stickers, ect using a small low pressure steam cleaner. it will not hurt your sailcloth and takes not only the sticker but also most of the glue when done right. ozzie
eastmeg2 Posted September 17, 2008 Posted September 17, 2008 Glad I found this thread as I'll likely be switching my own trike across from HGFA to RAAus near the end of the year, though in my case the trike is 18 months old.
