bushcaddy105 Posted September 19, 2006 Posted September 19, 2006 Anyone like to comment on their experience with Icom A-200 radios? My new one is back for repair under warranty for the second time in 30 hours of use.
Yenn Posted September 19, 2006 Posted September 19, 2006 Have a look at my comments in the "Handheld Transceivers" topic. They are good but it seems repairs are a problem once they play up. Ian
Student Pilot Posted September 19, 2006 Posted September 19, 2006 I just pulled one out, was starting to distort and volume was playing up. It had done around 7000 hours and it's the first trouble I've had with it. I have had a bit to do with them, that's the first trouble I've heard of with them, what's the installation like?
Guest Fred Bear Posted September 19, 2006 Posted September 19, 2006 I've used on for many a hundred hours and have never had a problem and I've never heard of anyone I know having problems with them. There's also a TSO'ed model based on the same unit, so if it's TSO'ed you can assume that it's of a good thoroughbread. They are certainly simple which is handy as there is less to go wrong and no software to worry about like some of the newer models. My only criticism is that the intercom is not voice-activated and is open all the time, however otherwise very powerful in transmit and easy to use.
Student Pilot Posted September 20, 2006 Posted September 20, 2006 Clem, depends on how you wire them, they can be set up for push to talk intercom.
Guest Fred Bear Posted September 20, 2006 Posted September 20, 2006 True.... and push to talk is great for noisy aircraft that a VOX might not be suitable for. There are other units available such as XCOM that has an intercom built in with VOX. I don't really know of any others with built in intercoms that work well.
