docjell Posted November 4, 2008 Posted November 4, 2008 I'm tired of running out of forward trim at cruise, despite all the usual remedies involving springs,split pins, going to the gym more often etc. Who has had the nerve to grind the bloody things off - and what happened next! Cheers Chris
ianboag Posted November 5, 2008 Posted November 5, 2008 Dunno about the trim tabs, but my new (and accepted by Jab) bracket seems to have fixed all that for me. Trim lever now sits where one would expect it to and all that. IB
Guest brentc Posted November 5, 2008 Posted November 5, 2008 We had a big discussion on this not long ago which culminated in Ian's new bracket. It will be in the Jabiru section and should be easy to find. Short of making a bracket like Ian, cutting off your trim tabs either entirely or partly is a valid action to take and will probably work. - I've done this myself along with many others.
Guest Bendorn Posted November 6, 2008 Posted November 6, 2008 I cut mine right back to about 12mm. Fixed it for me.
Guest Bendorn Posted November 6, 2008 Posted November 6, 2008 This was the thread..... > http://www.recreationalflying.com/forum/jabiru-users-group/12165-j430-trim.html#post59148
docjell Posted November 8, 2008 Author Posted November 8, 2008 Lets do it Thanks - I am venturing forth as we speak with a Dremel, a small angle grinder, 5 minute araldite, a few files and a bible. May speak again deo volente Cheers
Guest Bendorn Posted November 9, 2008 Posted November 9, 2008 Quote Thanks - I am venturing forth as we speak with a Dremel, a small angle grinder, 5 minute araldite, a few files and a bible.May speak again deo volente Cheers May the force be with you........
ianboag Posted December 14, 2008 Posted December 14, 2008 So what happened? You dremelled them off? Lack of trim problem all gone? Still need to do springs and things? IB
