kevinfrost Posted November 14, 2008 Posted November 14, 2008 I tried using my MP3 with the radio fitted to our 120. The result being a just audable signal which was shut down on transmit and stayed off. I queried Microair about it and they say the units require 1 Watt or more output or what ever is required to run the headset. Does anyone know of small pre amps or some other fix for this problem. Frosty
brilin_air Posted November 14, 2008 Posted November 14, 2008 Hi Frosty, We use an apple ipod with our microair radio, and the signal is not as loud as the signal from the headphones supplied with the ipod but is loud enough to listen too through the headsets in the plane, does it make any difference if you disconnect one set of headphones,(does the signal get louder) maybe a different brand of headset might not require as much power to receive a signal. Good luck Brian
AlanB Posted November 14, 2008 Posted November 14, 2008 Although I don't have a Microair radio, I purchased a music input adaptor from Barn Stormer Audio. It has the preamp required with auto mute option so you don't miss any radio calls. It runs off a 9V battery, but I modified mine to run off the planes 12V. I'm running it with a Icom A22 radio and so far I'm pretty happy with its performance. Barnstormer Audio - Aviation Headset Portable MP3 Music Adapter cheers Al
Guest brentc Posted November 14, 2008 Posted November 14, 2008 I used to have something that would be perfect. It came from a music shop and it was for an electric guitar. It was around $45 and ran on a 9-volt battery. The idea of it is so that you can play your electric guitar using a set of headphones as electric guitars don't usually have a pre-amp installed. So if you have an Allans music shop or similar they might be able to help, otherwise sounds like a Jaycar project perhaps.
kevinfrost Posted November 16, 2008 Author Posted November 16, 2008 Thanks, Brian, Linda, Al & brentc for you ideas. The unit I'm using is a cheap small mp3 unit with about a 4 hr play time. I'm thinking it's output value is probably quite a bit less than the likes of the Apple. Brentcs idea was probably the cheapest way out and Al's the best at around $100. I think I'll borrow a better quallity unit, try it,and go from there. Thanks for your time::thumb_up: Frosty
Modest Pilot Posted November 16, 2008 Posted November 16, 2008 Or next time you could get an X-Com radio. The price is about the same and the VOX interphone seems to work much better. Any old Mp3 or CD seems O K, instant cutoff if the radio receives a transmission, pilot isolate and inter com off swt etc. It's transmit power is also slightly higher. Not against Microair; I have two; the X-Com just works better.
Guest Nelson Smith Posted November 16, 2008 Posted November 16, 2008 Hi Kevin, Jacar have what is called "Pre-Champ" versitile preamplifier.It is a kit which needs to be assembled,but it will certainly do the job. Jacar Cat. No KC5166 $7.95 Nelson
danstee Posted November 19, 2008 Posted November 19, 2008 Wiring Diagram Does anyone have a wiring diagram showing how to connect an 'audio in' to the Microair radio (with or without amplifier)? Thanks in advance
Guest bazz107 Posted November 24, 2008 Posted November 24, 2008 Hi Danstee, Please email me at [email protected] and I will email you the Install manual. Thanks Byron:thumb_up:
