Dave Daniel Posted November 8, 2009 Posted November 8, 2009 Hi, I've just got a Mio Moov 300 and installed Mio Pocket 3.0 (Release 54) Which appears to work fine. I've downloaded OziExplorerCE (The one for ARM processors, I think this is the right one?). Copied the files onto the SD card and tried to run it on the Mio, I get an hourglasss but nothing else (I waited for 35 minuites before giving up.) Has anyone else had similar problems? Cheers Dave
Dave Daniel Posted November 8, 2009 Posted November 8, 2009 Quote Hi,I've just got a Mio Moov 300 and installed Mio Pocket 3.0 (Release 54) Which appears to work fine. I've downloaded OziExplorerCE (The one for ARM processors, I think this is the right one?). Copied the files onto the SD card and tried to run it on the Mio, I get an hourglasss but nothing else (I waited for 35 minuites before giving up.) Has anyone else had similar problems? Cheers Dave Just a quick update, OziExplorerCE seems to have corrupted when I copied it to the SD card, I downloaded it again, worked fine :big_grin: Cheers Dave
Tracktop Posted November 23, 2009 Posted November 23, 2009 Hi all Here is a link showing different screen sizes of a French equivalent to the "Slarti System" Looks like it to me anyway, I can't read french. (but I am told this software is freeware ) Previously I didn't want to risk trashing my, required for business Navman S300T by unlocking it and adding software but I hate it so much I decided it could only improve things, and if I did brick it, I would just have to replace it with another brand . So I also have started the process, even if only to decide if that's what suits me or I go a different track. (XC is getting close ) So far Backed Up Original - get active sync, then easy as Unlocked - easy as Loaded oziexplorer on PC and Navman - straight forward and seamless Ordered Maps - still to come Buy OziE - still to happen ( tomorrow) Drive around in car (truck) to see how it works. - done and seems fine Concerns i_dunno 1 - screen size is a bit small and hard to read for an old fella so how are those using the 7" screens finding theirs ? 2 - really need a stylus to operate ( finger is fine for original operation ) - my finger is just too fat -boy them buttons are little when you are bouncing along. Don't know how I will go in the trike in anything but dead still air, Might have to look at the Ross big button page Is the 7" screen any better? 3 - had a similar time problem to ???? where it kept reverting to the wrong time but that now seem resolved ( don't know how) And the good bits so far 1 - There is a good selection of pages, with good info, easy to read up close and in a still environment 2 - using a stylus seem to make operation much better 3. The GPS seems to find its location much easier than in its original form :confused: doesn't seem to make sense as it gets the same data from the GPS component, but I get a good fix inside with OzE whereas the original system gets no signal / fix at all. So to another question My last PDA died years ago but had other software on it that I think is included with normal ( but not mine) winCE eg text editor, pic viewer, organiser, calculator. etc Do you have these on yours, or are they freely available, best source for other (free) software? running wince 5 - arm processor AND Thanks Ross for a good thread :thumb_up:
Tracktop Posted November 28, 2009 Posted November 28, 2009 Hi Well I've had a couple of flys with it now and learnt a bit more Firstly the bad First flight was in overcast conditions and screen brightness was good and readable second flight ( today) was fine early morning but as the sun got higher the screen became totally unreadable - bugger just when I was starting to really like it. The time problem isn't resolved, I am wondering if the win settings have been made read only or something , will get to investigate that later. Now the good After changing the position of the gps so it was closer to eyes for viewing, the screen size was works fine. The button size that concerned me has a fix I didn't realise until I started using it. The hole screen is divided into a 3 X 3 matrix of 9 buttons that overlay over the top of what is displayed. One of the buttons changes the transluncy of the buttons so you can see where they are and read their operation. So most of the time you don't seem to meed to use the tiny buttons. If you build your own screens you can make 4 pages of these buttons, thats 36 big button functions to do what you need. Scanning and calibrating your own maps in is an easy function , as is merging a number of scanned images to reform the full map As stated elsewhere flying with the aviation chart on screen is really nice and although it doesn't have air space alarms it's easy to see if you are near violation
slartibartfast Posted November 29, 2009 Author Posted November 29, 2009 Good stuff Ray. Is that your S300T? My Mio is still readable in direct sunlight (and I get heaps) but could still do with some help. The 7" Chinese models look like they might suffer a bit too. These sunshades might be worth trying - There are lots on eBay for different models.
Tracktop Posted November 29, 2009 Posted November 29, 2009 Hi yes Ross my S300T They look easy - velcro dot on - Might try making up a shade and see how it goes. Weather looks bad for a few days so I'll have to wait to try a shade thumb_down Do have one other little drama at present - when I connect S300 to my PC, the PC tells me that the usb device is corrupt so I cannot load maps easily at present Suggestions?
denist Posted December 3, 2009 Posted December 3, 2009 FYI, OziCE has a new version available for download (2.32) which has fixed the magnetic variation problem.
slartibartfast Posted December 3, 2009 Author Posted December 3, 2009 Quote Do have one other little drama at present - when I connect S300 to my PC, the PC tells me that the usb device is corrupt so I cannot load maps easily at present Suggestions? First - try connecting it to another PC. If it still complains, there's a problem with the device. If it doesn't, reinstall the USB driver on your PC.
Upthere Posted December 4, 2009 Posted December 4, 2009 Hi Ross, Is it possible to have a copy of the file "hires.dat" email to me. Many Thanks, Colin
slartibartfast Posted December 4, 2009 Author Posted December 4, 2009 Quote Hi Ross,Is it possible to have a copy of the file "hires.dat" email to me. Many Thanks, Colin Hi Colin. It doesn't matter what (if anything) is in the file, just the presence of it makes Ozi double the resolution. In Windows, just right click a inside any folder, and choose New --> Text Document. Then just rename the file to hires.dat and copy it to the OziExplorerCE folder on your device. Or grab any existing small file and copy/rename it. I just did it on the 7" one I'm setting up for turboplanner. I'm now going to take it on a test run to Luskintyre tomorrow, just to make sure it's working properly .
Upthere Posted December 4, 2009 Posted December 4, 2009 Quote Hi Colin.It doesn't matter what (if anything) is in the file, just the presence of it makes Ozi double the resolution. In Windows, just right click a inside any folder, and choose New --> Text Document. Then just rename the file to hires.dat and copy it to the OziExplorerCE folder on your device. Or grab any existing small file and copy/rename it. I just did it on the 7" one I'm setting up for turboplanner. I'm now going to take it on a test run to Luskintyre tomorrow, just to make sure it's working properly . Hi Ross, Thanks for that, it worked OK. Can now read all.
Tracktop Posted December 4, 2009 Posted December 4, 2009 Quote First - try connecting it to another PC. If it still complains, there's a problem with the device.If it doesn't, reinstall the USB driver on your PC. Thanks Ross- device stopped charging on 12V yesterday, Plugged USB in again to PC and no charge led on device with that either so it looks like a navman fault. Gotta love that navman - NOT. Not that old so I guess it will be going back. I'll keep an eye and ear out for you at Luskintyre tomorrow - should be floating around the area if it's not too windy.
Tracktop Posted December 5, 2009 Posted December 5, 2009 Quote I'll keep an eye and ear out for you at Luskintyre tomorrow - should be floating around the area if it's not too windy. Hi Ross Good to meet at Lusky yesterday. Hope you enjoyed your day and had a good flight back
slartibartfast Posted December 6, 2009 Author Posted December 6, 2009 Yeah Ray - great to meet you. Thanks for dropping over to catch up. I'll post some pics later. On topic - I gave the 7" GPS a run yesterday. The good: It works perfectly well and the screen is very big. The bad: Not bright enough - the screen is very reflective, so the brightness is important. Also, the power lead comes out very easily. You would have to fix this so it didn't unexpectedly go flat. A hood would help with visibilty, but you'd still have to angle it toward a dark part of your cockpit. I much prefer my Mio. It's bright enough to be seen at all times, and a 4.3" screen is plenty.
pudestcon Posted December 6, 2009 Posted December 6, 2009 Quote Yeah Ray - great to meet you. Thanks for dropping over to catch up.I'll post some pics later. On topic - I gave the 7" GPS a run yesterday. The good: It works perfectly well and the screen is very big. The bad: Not bright enough - the screen is very reflective, so the brightness is important. Also, the power lead comes out very easily. You would have to fix this so it didn't unexpectedly go flat. A hood would help with visibilty, but you'd still have to angle it toward a dark part of your cockpit. I much prefer my Mio. It's bright enough to be seen at all times, and a 4.3" screen is plenty. I was thinking about the glare/reflection problem yesterday Ross as I was delivering some building materials to the airfield for our new hangar. I tried a hood/shroud made of matt black material which gave minimal improvement because of the lack of a dark part of the cockpit (in this case in the car). Got a feeling this is going to be an ongoing problem. It occurred to me that there are film products (3M) out there that people use on windows to reduce glare; I wonder if there is a product that would be suitable for this application which would not detract from the touch screen sensitivity. I'll check with 3M and let people know if I find something. Pud
slartibartfast Posted December 6, 2009 Author Posted December 6, 2009 I thought about that stuff too Pud. Might work, but would have to be thin to keep the touch screen working.
Tracktop Posted December 6, 2009 Posted December 6, 2009 Quote I thought about that stuff too Pud. Might work, but would have to be thin to keep the touch screen working. I think you can buy a screen saver film for the smaller sat navs including touch screen ones - they may have one for a 7". I thinks it's the very shiny surface that contributes to the problem.
turboplanner Posted December 6, 2009 Posted December 6, 2009 Don't worry Slarti, I've got X Ray eyes.
pudestcon Posted December 6, 2009 Posted December 6, 2009 I've asked for information on this product Slarti. 3M Vikuiti? - Manufacturers - Anti-Reflection Films (US)
Upthere Posted December 6, 2009 Posted December 6, 2009 Can some body help with this..... I've seen a program working on an iphone which displays a fully opporational atificial horizon. Is there a same or similar (freeware) program which will work with on a GPS using widowsCE operating system. Thanks
Guest Qwerty Posted December 6, 2009 Posted December 6, 2009 I was impressed by the AH on the iphone when I was playing with it on the ground....then, I took it for a fly. It is based on an accelerometer which means that it is basically useless. Sorry mate, Qwerty
pudestcon Posted December 7, 2009 Posted December 7, 2009 Vikuiti anti-reflective film Here is the brochure from 3M on the anti-reflective film Protects delicate LCD screens while significantly improving display readability. Practically every mobile electronic device today features an LCD screen—from handheld computers and automated data capture devices to personal digital assistants (PDAs). And although LCD screens have continued to improve over the years, they are still not nearly as durable as desktop CRT screens. To help your LCD screen last, it should be protected. One way to achieve this is with Vikuiti™ Removable Anti-Reflection Film (ARMR-200). This ultra-thin, multilayer film not only helps protect delicate LCD screens from scratches and damage that can lead to costly repairs, but also reduces screen surface reflections to minimize glare and increase clarity. And unlike other types of protective film, Vikuiti ARMR-200 film does not bunch up or leave air gaps that can result in image distortion. Since touch-display sensitivity is not affected by the film, Vikuiti ARMR-200 film is ideal for screens requiring a stylus. When it’s time to replace the film—every three to six months—a non-tacky elastomer adhesive allows the film to be easily removed with little or no residue. Vikuiti ARMR-200 film is available in a variety of sheet sizes and can be easily trimmed to accommodate just about any size screen. ARMR-200 Film 3Innovation Vikuiti™ Removable Anti-Reflection Film (ARMR-200) Limited Warranty: This 3M product will meet its published specification at the time of sale and for 3 months after application. If this product is defective, your exclusive remedy shall be, at 3M’s option, replacement of the product or refund of the purchase price. Limitation of Liability: 3M will not be liable for any loss or damage arising from this product, whether direct, indirect, special, incidental or consequential. Vikuiti™ Removable Anti-Reflection Film (ARMR-200) 3 Optical Systems Division 3M Center, Building 275-6E-07 St. Paul, MN 55144-1000 Minimum 10% Post-Consumer Fiber Vikuiti and the Vikuiti “Eye” symbol are trademarks of 3M. All other trademarks are property of their respective owners. Printed in U.S.A. © 3M Rev 3/2005 75-0500-5214-3 Vikuiti™ Removable Anti-Reflection Film (ARMR-200) is an inexpensive way to help protect delicate LCD screens from scratches and fingerprint damage while improving clarity and readability. • Durable hardcoat—lasts 3-6 months depending on use • Features an anti-reflective coating—for improved clarity and readability • Smudges and fingerprints wipe off easily—thanks to an easy-to-clean layer on the film • Removable—a non-tacky adhesive allows the film to be removed • Matte surface—for less slippage when writing with a stylus Vikuiti Removable Anti-Reflection Film’s unique multilayered construction reduces glare, makes it easier to wipe off fingerprints and helps shield screens from scratches. Vikuiti ARMR-200 film will fit several display types. A matte coating provides a more natural non-slip writing surface. Non-tacky adhesive will not trap bubbles during application. Anti-Fingerprint Layer Anti-Reflection Coating Matte Hardcoat 5 mil PET 1 mil Adhesive Disposable Liner Nominal film properties Thickness Base 5 mil Adhesive 1 mil Pencil Hardness > 3H Durability 10 rubs at 160g/in2 Solvent Resistance Window cleaner, IPA, 10W-40 oil, Coke®, coffee, Sharpie®, water Environmental Heat/Humidity 65°C/95% RH for 500 hrs Dry Heat 85°C for 500 hrs Thermal Shock Resistance (Hot/Cold) -35°C to 85°C, 1hr cycles for 8 days Specular Reflectance < 1.1% Transmission > 92% Gloss 75-110 gloss units Typical values, not for specification purposes. We’re easy to reach! 1-800-553-9215 Visit our Web site at www.Vikuiti.com Cheers, Pud
Tracktop Posted December 7, 2009 Posted December 7, 2009 Hi Looking at GPS's in stores today. All the Mio units ( and only the Mio units) like Ross uses are claiming to have anti glare screens, which may explain why his seems better than the 7" no name version, and my Navman. So Pud your anti glare film may just give the improvement required. Certainly worth your money to try it for me :stirring pot:............. bad Ray:mulie: Interestingly I was also looking at small lap tops ( 10.5" but am told an 8.5" touch screen is also available) - thought maybe not much bigger than a 7" display and could run other apps as well, and has a real keyboard - need a remote gps though. In D Smith they had about 6 different models, 5 with shiny screens 1 with a matte screen and even with just the shop lights the mat screen seemed much brighter.
pudestcon Posted December 7, 2009 Posted December 7, 2009 Might have to visit Dick Smith's to see if they have any of the anti-glare film so I can spend some money and try it out for you Ray:big_grin:
Tracktop Posted December 7, 2009 Posted December 7, 2009 That's very kind, generous and thoughtful of you Pud Thank you What a wonderful forum
