Guest Brett Campany Posted December 20, 2008 Posted December 20, 2008 Hey guys, if you've got the Evektor EV97 for FSX and you've found that it keeps going to the left, well I've been working on the fix. Follow these steps- Open: Microsoft Games/Microsoft Flight Simulator X/simobjects/airplanes/ev97 Look for the aircraft.CFG file and double click it. When it asks what program to open it with, use "Notepad". Now before you make any modifications, make a copy of the aircraft.CFG file and put it in another folder incase this doesn't work for you. I'm 99.9% sure it will work though. OK, open the "aircraft.CFG" file inside the EV97 folder and over write the contents with the text below. Once you've done that, close the file, click "yes" to save it and go flying. Any issues, place them here. COPY EVERYTHING BELOW THIS LINE. // EV-97 Eurostar Aircraft configuration file // by Oskari Syynimaa [Fltsim.0] title=EV-97R Eurostar OH-U507 sim=EV97_Eurostar_Rotax_912UL model= panel= sound= texture=oh_u507 kb_checklists= kb_reference= atc_id=OH-U507 atc_parking_types=RAMP ui_manufacturer=Evektor-Aerotechnik ui_type=EV-97R Eurostar ui_variation=OH-U507 atc_heavy=0 atc_airline= atc_flight_number= description=OH-U507, the real aircraft that this model is built upon. Flying in Finland. Rotax 912UL 80HP version. [Fltsim.1] title=EV-97R Eurostar SE-VAR sim=EV97_Eurostar_Rotax_912UL model=1 panel=1 sound= texture=se_var kb_checklists= kb_reference= atc_id=SE-VAR atc_parking_types=RAMP ui_manufacturer=Evektor-Aerotechnik ui_type=EV-97R Eurostar ui_variation=SE-VAR atc_heavy=0 atc_airline= atc_flight_number= description=SE-VAR is one of Höganäs Flygklubbs´ two Eurostars. Rotax 912UL 80HP version. [Fltsim.2] title=EV-97R Eurostar OH-U402 sim=EV97_Eurostar_Rotax_912UL model= panel= sound= texture=oh_u402 kb_checklists= kb_reference= atc_id=OH-U402 atc_parking_types=RAMP ui_manufacturer=Evektor-Aerotechnik ui_type=EV-97R Eurostar ui_variation=OH-U402 atc_heavy=0 atc_airline= atc_flight_number= description=OH-U402. Flying in Finland. Rotax 912UL 80HP version. [General] atc_type=Ultralight atc_model=Eurostar performance=Wing Span: 8,10 m\nLenght: 5,98 m\nEmpty Weight: 269 kg\nMaximum Gross Weight: 450 kg\nFuel Capacity: 65 l\nEngine: Rotax 912 UL\nSeating: 2\nCruising Speed: 180 km/h\nService Ceiling: 5000 m\nRange: 750 km Category=airplane [CameraDefinition.0] Title="Left Wing" Guid={3A09FD6C-D906-4d8f-A5CD-FA4F5E0C12ED} Description=View from the left wing tip Origin=Center SnapPbhAdjust=Swivel SnapPbhReturn=FALSE PanPbhAdjust=Swivel PanPbhReturn=FALSE Track=None ShowAxis=FALSE AllowZoom=TRUE InitialZoom=1.0 ShowWeather=Yes InitialXyz=-7.5,0.75,0 InitialPbh=5,0,90 XyzAdjust=TRUE Category=Aircraft ClipMode=Minimum [Weight_and_balance] max_gross_weight=992.080 empty_weight=593.040 reference_datum_position=0.928,0.000,0.430 empty_weight_CG_position=-0.735,0.000,1.400 max_number_of_stations=3 station_load.0=95.000000,-1.640000,-0.150000,0.700000,Pilot station_load.1=95.000000,-1.640000,0.150000,0.700000,Passenger station_load.2=0.000000,-3.870000,0.000000,0.700000,Baggage ;Moments of Inertia empty_weight_pitch_MOI=700.000 empty_weight_roll_MOI=200.000 empty_weight_yaw_MOI=900.000 empty_weight_coupled_MOI=0.000 CG_forward_limit=1.080 CG_aft_limit=1.390 [Flight_tuning] cruise_lift_scalar=1.000 parasite_drag_scalar=1.000 induced_drag_scalar=1.000 elevator_effectiveness=1.000 aileron_effectiveness=1.000 rudder_effectiveness=1.000 pitch_stability=1.000 roll_stability=1.000 yaw_stability=2.000 elevator_trim_effectiveness=1.000 aileron_trim_effectiveness=0.000 rudder_trim_effectiveness=0.000 hi_alpha_on_roll=1.0 hi_alpha_on_yaw=1.0 p_factor_on_yaw=1.0 torque_on_roll=1.0 gyro_precession_on_roll=1.0 gyro_precession_on_yaw=1.0 [GeneralEngineData] engine_type=0 Engine.0=4.567,0.000,1.039 fuel_flow_scalar=1.477 min_throttle_limit=0.0 [Piston_engine] power_scalar=1.0 cylinder_displacement=34.00 //73.9 compression_ratio=9.0 number_of_cylinders=4 max_rated_rpm=5800 max_rated_hp=60.000 fuel_metering_type=0 cooling_type=0 normalized_starter_torque=0.300 turbocharged=0 max_design_mp=0.000 min_design_mp=0.000 critical_altitude=0.000 emergency_boost_type=0 emergency_boost_mp_offset=0.000 emergency_boost_gain_offset=0.000 fuel_air_auto_mixture=1 auto_ignition=0 max_rpm_mechanical_efficiency_scalar=1.000 idle_rpm_mechanical_efficiency_scalar=1.000 max_rpm_friction_scalar=1.200 idle_rpm_friction_scalar=0.500 [Propeller] thrust_scalar=1.5 propeller_type=1 propeller_diameter=5.330 propeller_blades=3 propeller_moi=3.000 beta_max=0.000 beta_min=0.000 min_gov_rpm=0.000 prop_tc=0.000 gear_reduction_ratio=2.27 fixed_pitch_beta=18.375 low_speed_theory_limit=80.000 prop_sync_available=0 prop_deice_available=0 prop_feathering_available=0 prop_auto_feathering_available=0 min_rpm_for_feather=0.000 beta_feather=0.000 power_absorbed_cf=0.000 defeathering_accumulators_available=0 prop_reverse_available=0 minimum_on_ground_beta=0.000 minimum_reverse_beta=0.000 [Electrical] max_battery_voltage=12 generator_alternator_voltage=14 max_generator_alternator_amps=28 avionics_bus=0,3.5,9.0 avionics=1,3.5,9.0 additional_system=0,2,8.5 fuel_pump=0,5,6.0 starter1=0,50,6.0 light_strobe=0,3,8.5 [Contact_points] point.0=1,2.70,0.00,-2.9,1500,0,0.575,30,0.13,2.0,0.8,0,0,0,0,0 point.1=1,-1.90,-2.70,-2.9,2500,1,0.575,0,0.13,2.0,0.8,0,0,2,0,0 point.2=1,-1.90,2.70,-2.9,2500,2,0.575,0,0.13,2.0,0.8,0,0,3,0,0 point.3=2,-4.10,-13.15,0.45,1600,0,0,0,0,0,0.0,0,0,5,0,0 point.4=2,-4.10,13.15,0.45,1600,0,0,0,0,0,0.0,0,0,6,0,0 point.5=2,-0.1,-11.70,0.00,1600,0,0,0,0,0,0.0,0,0,5,0,0 point.6=2,-0.1,11.70,0.00,1600,0,0,0,0,0,0.0,0,0,6,0,0 point.7=2,-14.20,-4.0,0.95,1700,0,0,0,0,0,0.0,0,0,9,0,0 point.8=2,-14.20,4.0,0.95,1700,0,0,0,0,0,0.0,0,0,9,0,0 point.9=2,-11.70,-3.75,0.95,1700,0,0,0,0,0,0.0,0,0,9,0,0 point.10=2,-11.70,3.75,0.95,1700,0,0,0,0,0,0.0,0,0,9,0,0 point.11=2,-14.60,0.00,4.90,1700,0,0,0,0,0,0.0,0,0,9,0,0 point.12=2,-13.30,0.00,4.70,1700,0,0,0,0,0,0.0,0,0,9,0,0 point.13=2,-12.70,0.00,-0.25,1800,0,0,0,0,0,0.0,0,0,5,0,0 point.14=2,4.96,0.00,1.00,1800,0,0,0,0,0,0.0,0,0,4,0,0 point.15=2,-2.80,0.00,2.95,1700,0,0,0,0,0,0.0,0,0,4,0,0 max_number_of_points=16 static_pitch=0 static_cg_height=2.3 gear_system_type=0 [Gear_warning_system] gear_warning_available=0 [brakes] parking_brake=1 toe_brakes_scale=0.75 [Exits] number_of_exits=1 exit_rate.0=0.29 [Views] eyepoint=-2.40,-0.81,2.06 [Radios] Com.1=1,1 Com.2=0 Nav.1=0 Nav.2=0 Adf.1=0 Transponder.1=1 Marker.1=0 [Lights] light.0=1,-2.70,-13.20,0.35,fx_navred light.1=1,-2.70,13.20,0.35,fx_navgre light.2=1,-2.75,-13.20,0.35,fx_strobe light.3=1,-2.75,13.20,0.35,fx_strobe light.4=1,-13.60,0.00,5.00,fx_strobe_ev97 [Keyboard_response] elevator=100,180 aileron=200,1000 rudder=200,1000 [Direction_indicators] direction_indicator.0=1,0 [Attitude_indicators] attitude_indicator.0=2 [Turn_indicators] turn_indicator.0=1 [Airspeed_indicators] airspeed_indicator.0=1,0 [Effects] wake=fx_wake water=fx_spray dirt=fx_tchdrt startup=/ concrete=/ touchdown=/ [smokesystem] smoke.0=4.567,0.000,1.039,ev97_fire [Fuel] LeftMain=-3.410,0.000,0.000,13.7,0.766 RightMain=-3.410,0.000,0.000,13.7,0.766 fuel_type=1 number_of_tank_selectors=1 electric_pump=1 [Airplane_geometry] wing_area=105.920 wing_span=26.570 wing_root_chord=4.100 wing_dihedral=3.000 wing_incidence=3.000 wing_twist=0.000 oswald_efficiency_factor=0.770 wing_winglets_flag=0 wing_sweep=0.000 wing_pos_apex_lon=0.000 wing_pos_apex_vert=0.000 htail_area=20.990 htail_span=8.200 htail_pos_lon=-11.562 htail_pos_vert=0.935 htail_incidence=0.000 htail_sweep=0.000 vtail_area=10.760 vtail_span=4.070 vtail_sweep=34.000 vtail_pos_lon=-10.460 vtail_pos_vert=0.747 elevator_area=15.000 aileron_area=4.520 rudder_area=4.310 elevator_up_limit=25.000 elevator_down_limit=20.000 aileron_up_limit=20.000 aileron_down_limit=15.000 rudder_limit=30.000 elevator_trim_limit=25.000 spoiler_limit=0.000 spoilerons_available=0 aileron_to_spoileron_gain=0.000 min_ailerons_for_spoilerons=0.000 min_flaps_for_spoilerons=0.000 auto_spoiler_available=0 positive_g_limit_flaps_up=4.000000 positive_g_limit_flaps_down=2.000000 negative_g_limit_flaps_up=-1.500000 negative_g_limit_flaps_down=-1.500000 [Reference Speeds] flaps_up_stall_speed=38.000 full_flaps_stall_speed=31.000 cruise_speed=90.000 max_indicated_speed=146.000 [Autopilot] autopilot_available=0 flight_director_available=0 autothrottle_available=0 default_vertical_speed=700.000000 pitch_takeoff_ga=8.000000 max_pitch=10.000000 max_pitch_acceleration=1.000000 max_pitch_velocity_lo_alt=2.000000 max_pitch_velocity_hi_alt=1.500000 max_pitch_velocity_lo_alt_breakpoint=20000.000000 max_pitch_velocity_hi_alt_breakpoint=28000.000000 max_bank=25.000000 max_bank_acceleration=1.800000 max_bank_velocity=3.000000 max_throttle_rate=0.100000 nav_proportional_control=9.000000 nav_integrator_control=0.250000 nav_derivative_control=0.000000 nav_integrator_boundary=2.500000 nav_derivative_boundary=0.000000 gs_proportional_control=9.520000 gs_integrator_control=0.260000 gs_derivative_control=0.000000 gs_integrator_boundary=0.700000 gs_derivative_boundary=0.000000 yaw_damper_gain=0.000000 [Forcefeedback] gear_bump_nose_magnitude=6000 gear_bump_nose_direction=18000 gear_bump_nose_duration=250000 gear_bump_left_magnitude=6000 gear_bump_left_direction=35500 gear_bump_left_duration=250000 gear_bump_right_magnitude=6000 gear_bump_right_direction=00500 gear_bump_right_duration=250000 ground_bumps_magnitude1=3250 ground_bumps_angle1=8900 ground_bumps_intercept1=5.0 ground_bumps_slope1=0.48 ground_bumps_magnitude2=750 ground_bumps_angle2=9100 ground_bumps_intercept2=0.075 ground_bumps_slope2=1.0 crash_magnitude1=10000 crash_direction1=01000 crash_magnitude2=10000 crash_direction2=9000 crash_period2=75000 crash_duration2=2500000 [stall_warning] type=0 stick_shaker=0 [Flaps.0] type=1 span-outboard=0.52 extending-time=1.8 system_type=3 damaging-speed=100.000 blowout-speed=120.000 lift_scalar=0.900 drag_scalar=0.800 pitch_scalar=0.300 flaps-position.0=0.000,0.000 flaps-position.1=15.000,0.000 flaps-position.2=30.000,0.000 flaps-position.3=50.000,0.000 [Hydraulic_system] normal_pressure=0.000 [pitot_static] pitot_heat=1.000000 [vacuum_system] max_pressure=5.000000 vacuum_type=1 electric_backup_pressure=0.000000 engine_map=1,1,1,1 [pneumatic_system] max_pressure=0.000000 bleed_air_scalar=0.000000 [deice_system] structural_deice_type=0
