River Posted May 27, 2006 Posted May 27, 2006 Dose anyone know of a recreational/ultralight aircraft that may be similar to the GA version shown here in the photograph? I’m aware of highwing versions of the likes of RANS, Fisher and Storch examples but so far I have not been able to source a lowlight version… ? Anyone know of any? Rodger
Guest TOSGcentral Posted May 27, 2006 Posted May 27, 2006 Not sure if this will be of assistance or not as the types I am about to mention are a bit ‘swisher’ that the old Pawnee! They are also motor gliders but operate very efficiently as normal use powered aircraft. They all have spoiler/airbrake systems so a different form of approach control will have to be learnt. Sheibe SF28 Tandem Falke. MTOW of 590 kg, single central wheel with wing outriggers. Limbach VW 2200 engine (usually with 2 position v.p. and full feather). Caution is needed as there is a cowl flap system and you can rapidly cook the engine if this is mismanaged (eg left closed for take-off). Wood/fabric wings and empennage; tube steel, fabric covered space frame fuselage with glass front skinning. Now out of production and none in Oz – there are still plenty around in Europe. I really enjoyed flying them and easily out-soared a Blanik in one. Christian Gad (the designer) flew one over from Germany to Lasham UK in much the same time as I had done the trip in a Cherokee 140. Fournier RF5. Same general layout as the ’28 above but with retracting gear. All wood. I have no weight data but again is similar to the ’28 but with less soaring performance and leaning more towards light GA. If anything ever demonstrated what Rec Aviation could do then this aircraft did it by a brilliant piece of applied marketing and operations planning. An outfit (Sports Avia) opened at Biggin Hill and put in a fleet of them supporting a fleet of the single seat RF4 version (a poor man’s Spitfire they were known as), all at half the price of normal GA training. They had customers pouring out of their ears and the Pom GA schools went bananas over it! That was 35 years ago!!! Never knew what happened but someone must have found a way to torpedo it all – “Must not rock the boat chaps!†None in Oz to my knowledge. Fournier RF5B Sperber. Long wing (folding tipped) version of the ‘5 with a big bubble canopy for 360 degree vision and cleaner skinning. A better soarer (esp in Oz conditions) but again a bit towards GA. I think there may be one or two in Oz – check with GFA but they should fit into LSA OK if a bit heavy for RAA. I am as busy as a cut snake at the moment but if I can find time I will put some pics up as an edit later. Tony
Ed Herring Posted June 6, 2006 Posted June 6, 2006 Lightwing Pocket Rocket may fit the bill...rear seat pax 70kg http://www.lightwing.com.au/prdetails.htm
Ed Herring Posted June 6, 2006 Posted June 6, 2006 OK so you wanted a low wing....i have been waiting for someone to tell me i didn't know the difference between low and high wings...here you get both http://www.lightwing.com.au/kits.htmllooks like fun doesn't it? Ed Herring
