Hi All,
I have got to install a new washout tube/shock cord etc and was wondering if anyone has done it before and if there was any tips you could provide. I haven't had a close look at it yet but have been told it will be a bit a pain to do due to the lack of room to work in.
Any advise would be gratefully accepted. It is a Q2 wing if that helps or makes a difference.
Les
Crezzi,
I had a look at it today (didn't get right into it due to wind and rain and lack of hanger space)however it does look like the sail tension will have to be removed to get the room to move on the leading edge. Have you ever removed the sail tension on the tip? If so can you offer any advise? I would hate to not be able to get it back on or do damage due to wrong technique.
Les
I've done it on a few different wings & it varied between dead easy and a complete BA***ARD. In the latter case, we had fittted a new leading edge outer which maybe made it harder. No real trick - just remove the tensioning screws from the leading edge nose & slide the webbing off. Reverse to reassemble and be persistent but not brutal when sliding the webbing back on. Releasing the cross tube tension might help if you are struggling.
While you got the wing off - it might be worth checking that any SB have been done Eg http://www.pmaviation.co.uk/admin/upload_pdf/Sb97%20Q2%20WingTipInspection.PDF
http://www.pmaviation.co.uk/admin/upload_pdf/Sb84%20Sail%20Stitching.PDF
Hope that helps
John
