I recently purchased a U.S. gallon of Composiclean spray on wax from the Rec.Fly. Shop and yesterday polished the CT with it. The results were terrific.....a little goes a long way and the bugs come off easily and after minimal buffing, leaves a glossy finish.(and No...Ian did not pay me to write this)
Regards
Dave
Hi Dave,
Having now used the Composiclean, how long do you reckon a gallon will last you? Did you also buy a set of their special rags and are they worth the cost?
Paul
Hi Paul......I expect thegallon will last a long time because as I mentioned previously "a little goes a long way".Oncethe cloth you are using to apply the wax getssaturated, you only then need to occasionally spray a little on the area you are working. The product also contains a mild cleaning agent which very much makes it an 'all in one' operation.
I just usedan open weave, soft cloth (an old singlet will do) to apply the wax and then buffed it with another soft, dry cloth.
Regards
Dave
  • 2 years later...
Guest kentuckynet
Where can i buy this in the 1 gallon size???
G'Day Mate and welcome to the site.
Being in the US you would be better getting it directly from:
Composiclean, LLC
Hope this helps!
Guest kentuckynet
thanks for your help
