Would anyone have an Airstrips data base for Oziexplorer .
If not what is the best way to gather and process the info.
And also is there a directory for backyard strips which are just private strips and not for landing there except with an engine out.
Thanks everyone
Tony
I just purchased a 'Maptrax' WAC file and the airfield.txt file came with it. As yet i haven't figured out what Oziexplorer does with the text file.
Luke
I have had a look at the airfield.txt way point file and it is a dogs breakfast. I have re-edited it and it now imports into oziexplorer. The edited file is below.
In oziexplorer if you go to the load button and select 'Import waypoints from text file', point it to the airfield.txt file, select the WGS84 datum and Bob's your uncle.
Luke
Airfield.txt
Airfield.txt
Airfield.txt
Thanks Wags I will look into it
Thanks Luke and Ahlocks this is great just what I was after.
Thanks again everyone
The downside is there are missing council fields Example Tyagarah
In attachment
Airfield.txt
oziExplorergoogle.kml open in google earth
airfields.wpt put in data folder ozice
oziExplorergoogle.zip
