Guest Nickjaxe Posted February 28, 2009 Posted February 28, 2009 Rotaxparts.net and 800-Airwolf specializes in Rotax Parts for Ultralight and amature built aircraft. We ship worldwide and offer services in English and Espa?l. We ship our rotax parts world wide. - 800-Airwolf Rotax Parts Online Store features Ultr Bought myself one of the above, its the prop balance tool with the little spirit level on the end of the string, reading the instructions it says the the pivot point should be a little above the centre of mass and is suitable for std 1"in hole props, My prop is a std 3 blade warp drive with flanges both sides of the hub so no solid 1" bore all the way through the prop hub, so my pivot point would be quite high or low if I used one of the outer flanges to centre the tool, So I am know thinking this tool is not suitable for my prop although it was described as suitable for props with std 1" hub, Any of you guys advise if I can use it with a std warp drive prop in any way. Nick.
Kev Posted May 19, 2009 Posted May 19, 2009 Nick Hi, Sounds like you may need to make or acquire an adapter for the Warp Drive prop. Suggest you contact Conrad Beale at conairsports.co.uk He will almost certainly be able to let you know if it is doable and what with. Safe flying Kev
