just a fancy name for your best aviation photos, not for monthly comps, but just to show them off..:thumb_up:
well, i have a new camera, and an new technique, what ya think?
my new camera is a canon 450D, and the technique i have learned is HDR, High dynamic range, basically 3 shots are taken, at 3 different exposure levels, and then all 3 are merged to create the HDR image.
shooting the one on approach was hard, none worked out, so i had to cheat, by taking one image in RAW format, copying it 3 times and manually adjusting the RAW image to get the 3 different exposure levels.
any movement or change in distance/focus etc will cause the final shot to be blurred, or have "ghosts" so it was nearly impossible to get the finals shot without a noticeable difference in the images, as the aircraft is moving, so is the distance to the subject.
Ultralights. Couldn't you have used 1 raw image modified 3 times and joined together?
I have never thought of doing what you did, but will have to give it a go.
canon 5D
5d, on black and white setting gives rather nice exposed shots too
sexy
Slarti
There is no doubt your Morgan is the sexiest plane in the Ultralight range.
Nice picie of the windsock.THOUGHT i WOULD KEEP THE THEME GOING
