Guest pelorus32
Three modes:
  • Mode A - the Squawk Code assigned by ATC or the VFR code or the emergency codes
  • Mode C - the Altitude Code. Modes A and C are almost always found together though Mode A was developed before Mode C;
  • Mode S - this provides an individual code for the airframe and also provides Mode A (on second thoughts Mode A is replaced by Mode S I think) and C capability.
See here for description of Mode S: Mode S technology
ADS-B relies on a type of Mode S transponder and comes in at least 2 Standards and 2 capabilities.
The capabilities are ADS-B Out and ADS-B In. It also requires a GPS source. Out simply sends your ADS-B data whilst In also allows a Cockpit Display of Traffic Information (CDTI) to display info on other a/c.
The Standards are 1090ES (for 1090Mhz Extended Squitter) which is the chosen Australian Standard and the other standard that they are going to use in the US - name evades me atm. But of course they are incompatible:sad:.
A standard Mode S is interrogated on 1030 from memory and responds on 1090 but doesn't have the ES.
It appears however that the Trig is 1090ES so that's good, however it only does ADS-B out if that matters.
Regards
Mike
