Ultralights Posted April 21, 2009 Posted April 21, 2009 just a quick one, what type of resin is used in the Jabiru airframe? i need to do a small repair...
Derby Posted April 21, 2009 Posted April 21, 2009 Hi Ultralights, it's Araldite LC 3600 resin and Hardener. Jabiru can send it to you. I brought 1 lt it cost about 42 dollars a couple of weeks ago.With the hardner. Rory
Ultralights Posted April 21, 2009 Author Posted April 21, 2009 thanks for that, fortunately i work in a composites workshop, so resins, and fibreglass etc are no problem, i just needed to kno what if the resin is Polyester,vinylester,polycarbonate or epoxy systems, so i know what type to borrow from work. if my memory serves me correctly, then LC36 is an epoxy. thanks for your help.. rob.
Derby Posted April 21, 2009 Posted April 21, 2009 Don't forget to return it when your finished with it. Ha Ha Rory
Guest Cloudsuck Posted April 23, 2009 Posted April 23, 2009 thanks for that, fortunately i work in a composites workshop, so resins, and fibreglass etc are no problem, i just needed to kno what if the resin is Polyester,vinylester,polycarbonate or epoxy systems, so i know what type to borrow from work.if my memory serves me correctly, then LC36 is an epoxy. thanks for your help.. rob. Yep, spot on .... it is Epoxy.
Ultralights Posted April 23, 2009 Author Posted April 23, 2009 now all i have to do is decide what type of resin to "borrow" heat resistant to 250 deg C? hmmm no, flexible resin? hmmm no, part doesnt change shape at all, metal impregnated resin?, no too heavy, and might effect radio and compass, nahh good old fashioned polyester friendly epoxy will do... shame its pink
Bruce Tuncks Posted July 28, 2009 Posted July 28, 2009 Jabiru Resin Not all epoxy resins are compatible with each other. Some are and some are not. I have seen a listing, but don't have it at hand. So be careful if you don't use the same stuff. Bruce
jabpilot Posted July 28, 2009 Posted July 28, 2009 Jabiru use Ceiba Geigy epoxy for the majority of construction. Araldite is used and supplied in small quantities in the kit but is not the same substance as above and will not mix properly (ie. mixing swapped resins and hardeners). It is supplied for quick, non-structual work only. Although not as easy to use as polyester or vinyl-ester as many aircraft are, epoxy is much stronger. Do not try to mix different formulations of epoxy. eg. AFI resin with Ceiba Geigy hardener. There are 20 different formulations to my knowledge. However, a foreign epoxy (non ceiba geigy formulation of resin and matching hardener) will still glue an original Jabiru fibreglass component well. I hope all this makes sense.
winsor68 Posted July 28, 2009 Posted July 28, 2009 What is a Jab made of? Sugar and Spice and all thing nice?
