G'Day All,
if this has been covered in a previous discussion, please re-direct me, otherwise.....
does anyone know if there are any suppliers of rotary A/C engines at around the 100hp range? I've looked everywhere I can think of on the net and though I've found some suppliers, they are all in the 200hp+ catagory. Everything else seems to point towards getting a 12A or 13B Mazda and doing the conversion yourself (plenty of sites & info on that). Any ideas?
Cheers,
Stewart
That brings back memories - I owned an RX2 an absolute rocket - once sat on 209 km/hr all the way down from Albury to the outskirts of Melbourne, however I spent many hours in the workshop pulling the engine donw and fitting new O rings, usually after a trip like that, or a long trip with a head wind.
Under those conditions, the heat from the chamber, or maybe the flame would reach down to the rubber o rings seals and burn them out.
The engine also had a torque curve like a needle and very little power in quiet suburban driving - you needed to keep the revs up, and under those circumstances it was a fuel guzzler.
At constant rpm under load in an aircraft, those are characteritics which could make it less desirable.
Geez, what revs would that be sitting at for that length of time...? no wonder you've blown up 14cars!!006_laugh.gif.0f7b82c13a0ec29502c5fb56c616f069.gif
Ps. that's pretty quick you know;)
The revs weren't all that high - maybe 4500 or something like that - can't really remember. Scarily fast - quite different to accelerating to that speed down a straight and slowing for a corner - you know that the slightest little error would launch you into the trees. I saw a few errors made Tomo, that's why I'm very cautious today.
The race car engines were another thing - 10,000 rpm at the end of the straight, lift off to unsettle the car then slam the throttle wide open to flick the tail out a little, tyre bite then do it 10 more times - pretty hard on the old two stroke (and don't you listen to Captain telling people I didn't put oil in the fuel).
Guest disperse
was going to tell you about the Rotamax engs 120hp N/A and 180hp turbo but a quick look at there web page leaves me thinking it's all gone south for Eric Berger an Co.032_juggle.gif.8567b0317161503e804f8a74227fc1dc.gif
