Guest Brett Campany
Anyone?
I'm keen at looking at the training required, where and how long etc.
Also could be a good post for others to get involved in becoming a level 2 maintainer as well.
Look forward to hearing what info you have.
Guest Qwerty
All the info that you need including the forms to apply are on the RAAus site.
It takes a while to fill in the forms, he wants all sorts of info. Post them off for assessment and wait. You will probably get a "line maintenance" restriction, but you will be on your way.
Here is a coutionary note though.
When you are a Level 2 and you are doing work on other peoples aircraft, you carry a hell of a responsability for the aircraft and the lives of the occupants. I think that taking on Level 2 responsibilities should not be done lightly.
Cheers.
Guest Brett Campany
Here is a cautionary note though.
When you are a Level 2 and you are doing work on other peoples aircraft, you carry a hell of a responsibility for the aircraft and the lives of the occupants. I think that taking on Level 2 responsibilities should not be done lightly.
Understood but you wouldn't do it if you didn't comprehend the level of responsibility as a maintainer.
Guest Brett Campany
OK, so the question really hasn't been answered but the link to the pdf file is what you're looking for.
For those who would like to take that avenue of becoming a Level 2 Maintainer, download the document and make sure you fit the criteriea.
Page 3 of the document is quite important.
SECTION 4.1.1 Annex A
NOTES ON APPLICATIONS FOR RA-Aus LEVEL TWO
MAINTENANCE AUTHORITIES
A Maintenance Supervisor Questionnaire is to be completed by all applicants for RAAus
Level Two Maintenance Authorities. Three criteria are set for assessing applicants
for Level Two Maintenance Authorities and determining if a person has the experience
and skills necessary to qualify for the issue of a Level 2 Maintenance Authority.
RA-Aus Level 2 Maintenance Authority holders accept a high degree of responsibility for
the maintenance and serviceability of ultralight aircraft. They are the RA-Aus's
equivalent of heavier aviation’s LAME’s who are required to pass significant written
examinations and have at least 4 years experience in the aviation industry before being
qualified. While ultralights may be simpler than most of the aircraft on the CASA
register, once airborne there is little difference to the outcome if sloppy maintenance
practices are perpetrated.
In applying for an RA-Aus Level 2 Maintenance Authority RA-Aus members must list IN
DETAIL their formal technical training and qualifications they have in the technical
trades. Fitting and Turning Certificates, TAFE Certificates etc should all be copied and
forwarded with the application. Details of experience in one or more of the trades should
be outlined in detail. Where this qualification is of only marginal relevance to aviation
maintenance a connection should be established.
The second criteria is experience in working on ultralight aircraft. Again, list IN DETAIL
all work performed on ultralight aircraft noting the nature of the work done and the aircraft
types involved. More, rather than less detail should be included and the work should be
able to be substantiated, if possible. Any information forwarded with the application will
not be used to prosecute members who may have been undertaking maintenance work
"illegally".
To assist the RA-Aus in assessing an applicant, the applicant is to obtain the
recommendation of two peers to the effect that they consider the applicant has the
experience and responsibility to be granted an RA-Aus Level 2 Maintenance Authority.
The recommendation may be from either two current holders of Level 2 Authorities or
from one Level 2 and a LAME. A Form that may be signed to meet this requirement is
also attached.
When issued RA-Aus Level 2 Maintenance Authorities may be unlimited or may be
restricted to permitting the applicant to work on specific aircraft, specific types of
aircraft, or only on specified components, for example engines. When forwarding the
Questionnaire and other paperwork, applicants should specify if they wish to have the
Authority limited to specific aircraft types or components. Notwithstanding any such
request, the RA-Aus may limit Authorities in any way.
The RA-Aus hopes to introduce courses for ultralight maintenance, including engine
maintenance, in the near future.
OK, so that said, for someone who has no qualifications or experience what so ever and would like to become a level 2 maintainer, what would they need to satisfy the requirements as state by RAAus?
That's what I'm asking.
Guest Qwerty
Brett
The only way to get a deffinative answer is to contact Steve Bell.
My understanding (please note this is my undertsanding not "the gospel") is that you tell Steve what you have done and what you can do, and he decides if you should be let loose and on what conditions that loosness is.
But if you really want to know, ask Steve. I'd like to know if he has set any formal description of what he feels indicates competancy.
cheers.
Guest Brett Campany
Will do Qwerty, Looks like I'll be off to TAFE for a couple of years :thumb_up:
