jetjr Posted July 29, 2009 Posted July 29, 2009 Im looking at getting a small electronic CO detector - It is small enough to go on a keyring, batteries last up to 2 years, has loud alarm and flashing light, alarm goes off at different levels of CO, calculates culmulative exposure too, Auto off after 12 hrs. They do under read a bit at 10000ft, but this shouldnt be an issue for most. Cost $179 USD delivered each, or I can get them for ~ $140 USD if I order 10x Anyone interested I can send data sheets etc. Cheers JR
Guest studentbiggles Posted July 30, 2009 Posted July 30, 2009 Hi Jetji, I'll have one to......I'll add it to my plane when I get it ???....I been researching these units on sites and they go up to $220, these sound great value and remembering a lot of us fly solo....I know I will be in the future and they are a definite must have on board...Only was discussing this with my CFI the other week Fly Safe Cheers Alley...Studentbiggles
jetjr Posted July 31, 2009 Author Posted July 31, 2009 This is the one I found, Gives a reading of CO, very small (67x35x15) 28g, battery operated, and does the calcs for time vs dose ie, 400ppm for 10 min may not be as bad as 120ppm for 1 hr Has alarms for this too Sensor is replacable, as is battery, 2 yr warranty Im getting a few so far. Price is down to $150 USD - if I get to 10 price drops alot maybe to $100 USD JR
Guest Maj Millard Posted August 2, 2009 Posted August 2, 2009 Yes, I do like the idea of an electronic Co2 detector, and I have noticed them on the market in the states. Definitly something I would like in my cockpit. Cost ?, well the way I've been putting money into the plane lately (GPS ELB, transponder-bargan at $1000, couldn't refuse, etc,etc.) I would like to pay around 50-60 AUS $, 100 at the most. Sorry to sound stingy but that's all I could afford right now. Until things get better it will have to be the fresh air vent wide open for me !!
Smokey Posted August 2, 2009 Posted August 2, 2009 Hi Guys FYI Spruce have these detectors for $US129:95 each. http://www.aircraftspruce.com/catalog/pspages/co300.php Perhaps Ian can get a good price through his contacts which should save on freight costs. Mark
perthjay85 Posted August 3, 2009 Posted August 3, 2009 why not enquire what clear prop can provide. If they can buy them with a trade name and ABN number they might be able to get them a bit cheaper for just a one off group buy.
Admin Posted August 3, 2009 Posted August 3, 2009 I'm on it but I would like to raise the question of life span. For say $130 US which is at 0.80c conversion = $162.50 plus battery costs For example an 18mth detector costs $15.95 from Clear Prop which for $162.50 you would get over 15 years worth of detection without the cost of batteries. If you use different aircraft you could just stick it on your flight plan folder or kneeboard. If you lose it then the outlay again isn't that much. Is the electronic ones false economy?
Guest mike_perth Posted August 3, 2009 Posted August 3, 2009 No electronic is not false economy when the one in your knee board cahnges color and your not looking at it as you are on the verge of passing out and dying because your already affected a loud alarm will hopefully alert you and youll react to fix the issue
jetjr Posted August 3, 2009 Author Posted August 3, 2009 Hi GuysFYI Spruce have these detectors for $US129:95 each. MODEL 300 POCKET CO from Aircraft Spruce Perhaps Ian can get a good price through his contacts which should save on freight costs. Mark Yep this is plus freight - they charge plenty for this, Id guess ~ $40 US If I can get up to 10, it should be below $120 US - landed Australia I already plan on talking to Ian to raise order number - keep in mind Ian has to make money on his, unfortunately Im not. JR
jetjr Posted August 3, 2009 Author Posted August 3, 2009 Not the one I was looking for but some info here Carbon Monoxide Detectors
RetiredRacer Posted August 3, 2009 Posted August 3, 2009 Put me down for one as well (I like the idea of that alarm going off)
jetjr Posted September 1, 2009 Author Posted September 1, 2009 CO detector - small electric These have arrived, look good, very small, and have flashing red light and screen which can calculate exposure and alarm - ie not just alarm at a high level but low level for a long time also Auto run for 12 hr then shuts off $160 Aud delivered, I have a few left JR
peter Posted September 1, 2009 Posted September 1, 2009 I will take one, if you could PM me I can arrange a direct funds transfer etc thanks for doing the leg work Peter
Jabiru Phil Posted September 2, 2009 Posted September 2, 2009 Thanks JR Transfered today P O Box 755 LOXTON SA 5333 Phil Duthoit
