The floats-on-a-swing-arm senders are
a legacy product from cars and other
vehicles that go back a very long way.
Making these things really accurate in more\
than one place is a bit fussy.
Years ago, we crafted an electronic signal
conditioning board for the Bonanzas and Barons
that allowed dead-on calibration of empty
and full. All other readings across the scale
simply fell where where the physics of the
sender dictates. The physics of these devices
are affected mildly by linearity of the wire
wound sensor resistor (usually within 5% of
true) but a whole lot by trigonometry of
the swing arm and tank geometry.
But as you've already recognized, the one
level you really want to be accurate is
the empty point. For this you can do some
things with series calibration resistors
and/or bending the float arm on the sender.
This CAN be a tedious, trial-by-error activity.
If it were my airplane, I'd probably craft
a microprocessor based signal conditioner
that would allow me to take readings at 5%
increments from empty to full and generate
a lookup table that converts as-installed
sender (transducer) readings into real
numbers. The BEST way to watch full levels
is with installation of a "dip stick" style
sensor at the low fuel warning level (generally
1/4 to 1/3 tank). Consider devices like this:
One of these stuck through the tank wall at
the warning level will light a lamp on the
panel at the desired fuel quantity with
no risk for drift of calibration. See:
http://www.gemssensors.com/content.aspx?id 82
This is the no-brainer, dead-nuts accurate
low liquid lever sensing method I know of.
Capacity fuel gages with processor augmentation
are also easy to calibrate . . . but I think I could get by with no active fuel gaging
other than a set of optical level detectors
cited above. [ATTACH]8555.vB[/ATTACH] by nuckolls.bob(at)aeroelect
