David S Posted September 5, 2009 Posted September 5, 2009 Hi Has anyone tried using a small 2" venturi tube to drive a turn and bank indicator? If so, does it work? My 2 stroke has no vacuum. David S
Yenn Posted September 6, 2009 Posted September 6, 2009 A lot of the old GA planes used an external venturi, but I am not sure of the size. 2" ought to be OK i think.
facthunter Posted September 7, 2009 Posted September 7, 2009 True. Place it where it gets a fair bit of wind off the prop then you will have the instrument functioning on the ground (with a bit of luck. As Yenn says the old aircraft ALL had them. (before they had electrics and vacuum pumps.) Nev.
newairly Posted September 9, 2009 Posted September 9, 2009 Have a look at this article from Flight Safety Magazine in 1999 http://www.casa.gov.au/fsa/1999/jul/FSAinst.pd It discusses the use of a venturi as a backup system to a vacuum pump. Phil
newairly Posted September 9, 2009 Posted September 9, 2009 Whoops, try http://www.casa.gov.au/fsa/1999/jul/FSAinst.pdf Phil
David S Posted September 10, 2009 Author Posted September 10, 2009 Thanks Gentlemen That's given food for thought David S
