Dear Trikers,
I am looking for replacement visors for both of my helmets as they are a little too scratched up. I used to buy them from Aerial Persuits but apparently they are no longer available. I've attached 2 pictures (it fits to the helmet via three 'press studs')
Any advice, i'd be greatful :)
regards.......dennis
Harry Mendelssohn seems to stock a similar looking helmet so they might also supply replacement visors (ozpilot.com.au - Pilot Supplies from Mendelssohn Pilot Supplies).
Failing that you could try Bob Heath in the UK - they make replacement visors for pretty much every helmet though I don't know if there are any Aussi delaers / distributors
Hope that helps
John
helmet visor
Hi Dennis dont know if this will help i have a motorbike helmet THH brand by SAI Global it looks identical to yours and was available at bike shops they had replacement visors try your local bike shop hope this helps ( safe skies ) JOHN.:thumb_up:
Just out of interest John - do you use headsets with your motorbike helmet ?
John
Thanks Mark! i've just found out they still make those visors for my helmet and i'm about to place an order with them.
i'll be definitely keeping his webpage handy - thanks again guys!!
Hi Dennis,
Just having a look at the flycom site Prices & Products and this is what they have to say regarding their visors: Note: These visors have 3 press studs and are supplied with 2 steel security screws, spacer and washers. They are designed to fit the Flycom helmet but will fit any helmet with 3 standard press studs. For use on other helmets such as Comunica and Lynx please request the visor without the press studs, or you can easily remove them yourself.
Regards Bill
  • 1 month later...
Hi Guys - thanks so much for your valuable input. I have now got myself two new visors for my helmets from the UK.
thanks again & regards :thumb_up:
