TechMan Posted December 19, 2006 Posted December 19, 2006 Hi All, A brief note to say that RA-Aus has received another report of a Rospeller propeller losing a blade in flight. The first being a year ago. I am in contact with the factory about this (again) as this is the second blade we have lost on this particular brand. Preliminary reports indicate that the 4 bolts holding the blade into the hub through tension, have failed. A detailed examination of the part will be carried out and recommendations made, in conjunction with the factory, in order to prevent further failures. If you have access to a different propeller, please use that in the meantime. I will be contacting operators of Rospeller props and asking them to refrain from using the prop until a solution has been worked out. Chris
A321Flyer Posted May 21, 2007 Posted May 21, 2007 Are there any news concerning the Rospeller prop failures? Martin
