Where can I purchase Avex countersunk rivets for the Savannah in Aust
Guest Maj Millard
Due to the skins being very thin on the Savannah (.016 mostly)you may not be able to use countersunk rivits. They will leave you with little holding surface.
>>>>countersunk-head rivets are used with modified nose piece in the puller to form a low profile domed head....not sure if stocks are in Oz...maybe Sport Air (former Zenith agents in QLD)..or Outback Aircraft.....how many are you in need of,Robert? ..A3 or A4's?
Try Aviaquip p/l at Cheltenham (Moorabbin airport) ask to speak to Ken. Phone 03 9585 1211. They carry all types of riverts. Another one to ask is Coastal Aviation 07 5448 8991 Rob Stowe, he is also a good one to try for the info. We are in the process of rebuilding our Gazelle & are up to the riverting stage at the moment. (not a cheap item) Good luck
How many and which size are you after as I have just finished my Zenith 601xl and have about 1000 left over [i think as I haven't counted them]of 1/8" csk head and 5/32"csk head avex rivets. Cheers
avex rivets
hi thruster
how much you want for them ???
hi thrusterhow much you want for them ???
On second thoughts I really should keep them for future use just in case. Cheers T87[been thinking of possible mods that I may do]
cheers T87
Thats what I would do.
Cant believe these rivets are so hard to get in Aust
I think it easier to order from Aircraft Spruce US
Robert
if you want to use countersunk rivets in thing skins, then create the countersink using the Dimple method. it creates a countersink and retains the materials original thickness.
I bought some he in Brisbane. I will have to get the contact details for you tomorrow.
On another subject, how close to flight testing are you Ian?????? I'm hoping to take my machine to the airport and do the final assembly/inspections next week Cheers T87
The CH601XL is still getting the Fifth Bearing fitted to the engine so we are a little way off yet. Been spending a lot of time bringing the third CH601XL that our Friend is building up to speed. This has slowed us down a little as well. On the other hand the CH701 is at the airport right now and it has passed the final inspections and will start flight testing this weekend. It should have been last weekend but due to the winds up here we had to cancel.
Will keep you posted. :thumb_up:
Ianrat
Here are the contact details for the supplier that i purchased my pop rivets from here in Brisbane.
SUN STATE FASTENERS
Call Ross
0408 456 380
Ianrat
Guest Maj Millard
Hey, you guys are going to be doing a shix load of dimpling for not a lot of drag reduction !!.........................................................:gerg:
We get all our Avex rivets from
Specialty Fastners, Fyshwick, ACT, Ph- 02 6280 7794.
Excellent mail order service, good prices.
Part number for the 1/8" countersunk head is 01604-100412.
JG
On the Zenith we use a special nose [concave ground] bit on the riveter which domes the CSK head to a lower profile shape and is supposed to work harden it as well [not totally convinced about that] Cheers
That Zenith method of doming the c/s heads works really well. The taper of the c/s fits tight even if the hole is a bit oversize, and the head pulls down really tight. Especially for a Savannah kit where the punched holes are actually 9/64" rather than #30, to make it easier to align I suppose.....
JG
Thanks guys for your input. I ended up ordering rivets from aircraft spruce in the US.
Although I now have a few contacts in Aust for future purchases
RobertW
