Tomo Posted October 5, 2009 Posted October 5, 2009 I had this in my LL endorsement thread, but I thought it may as well have its own. So... - What is the 2 heights at which you should ONLY fly at when flying low level?
Deskpilot Posted October 5, 2009 Posted October 5, 2009 Above the ground and above obstructions. :kboom:
Guest Maj Millard Posted October 6, 2009 Posted October 6, 2009 Above powerline height would be one guess, and above lowest safe altitude, lest thy hit the ground ? and oh above any levee height on landing.............................
Tomo Posted October 6, 2009 Author Posted October 6, 2009 Staying above the ground is a REAL plus, especially when flying, other wise it'd be driving:blush: But yes, staying ABOVE power line height, or BELOW power line height... NEVER AT power line height... Why? well....... self explanatory really. If you can't go under a power lines safely, due to terrain, then stay above them... don't got along at the same height. Cause it'll get ya between the teeth!:ah_oh:
JimG Posted October 6, 2009 Posted October 6, 2009 Here is what I know....NEVER fly below the level of ridge to ridge or into valleys without doing a full inspection for power lines. JimG BTW, passed my LL flight test yesterday :thumb_up:
HEON Posted October 6, 2009 Posted October 6, 2009 Now thats a question! Above:1.The ground height;2.Min authorised height:question:
Guest Maj Millard Posted October 6, 2009 Posted October 6, 2009 As I always say:" Flying is the best way to fly !"....................................
Derby Posted October 6, 2009 Posted October 6, 2009 Hi Tomo, An aircraft must not fly over any city, town or populous area, at a height lower than 1000ft; or any other area at a height lower than 500 ft. Heitht specified in the above the hightest point of the terrain and any object on it, within a radius of: in the case of an aircraft other than a helicopter-600 m. In case of a helicopter-300m.
Tomo Posted October 6, 2009 Author Posted October 6, 2009 Hi Tomo, An aircraft must fly over any city, town or populous area, at a height lower than 1000ft; or any other area at a height lower than 500 ft. Heitht specified in the above the hightest point of the terrain and any object on it, within a radius of: in the case of an aircraft other than a helicopter-600 m. In case of a helicopter-300m. Yes that's correct. The question was really about low level though, so considering you have been given permission to fly low level in a particular area, you then have to asses how low you really are going to go, etc... It's just a general rule of thumb to not get caught in a line as easily... because flying along at 30ft is a pretty good low level height, 'viewing wise', but that's where all the hot wires are ready to get you also! Either stay under, or over... don't doodle in between!
storchy neil Posted October 10, 2009 Posted October 10, 2009 power line height is not safe ask me i have had that happen to to me on the 9 9 07 two years latter my plane is not flying neil
Tomo Posted October 10, 2009 Author Posted October 10, 2009 power line height is not safe ask me i have had that happen to to me on the 9 9 07 two years latter my plane is not flying neil Really? Would you like to tell us what happened? so we can all learn from it...
farri Posted October 13, 2009 Posted October 13, 2009 But yes, staying ABOVE power line height, or BELOW power line height... NEVER AT power line height... Why? well....... self explanatory really. /QUOTE] Tomo,I`ve got a question ,"What is power line height"?. I wasn`t aware there was a standard height. Cheers, Frank.
Tomo Posted October 13, 2009 Author Posted October 13, 2009 Tomo,I`ve got a question ,"What is power line height"?. I wasn`t aware there was a standard height. Well there isn't really a "set" powerline height, but most times it is 8-10mts above the ground out here... Obviously the high tension powerlines are a lot taller, but you don't generally get them in the bush. I guess when you get the permission to fly on a persons property, you just check what height there lines run at... and stay well under or over that height...
farri Posted October 13, 2009 Posted October 13, 2009 In my opinion,whenever refering to powerline height,it should be pointed out that there is no uniform height and that powerlines also sag, therefore, the middle of the lines may be well bellow the height of the poles that support them. Frank.
Tomo Posted October 13, 2009 Author Posted October 13, 2009 In my opinion,whenever refering to powerline height,it should be pointed out that there is no uniform height and that powerlines also sag, therefore, the middle of the lines may be well bellow the height of the poles that support them. Yes very true. I guess you just have to weigh up the situation, and choose the best one.:thumb_up:
maulonir Posted October 14, 2009 Posted October 14, 2009 Some high tension power lines also have a single earth wire that can be a couple of metres below the main lines and can be difficult to see.
GraemeK Posted October 14, 2009 Posted October 14, 2009 My strip which goes under a power line has a pole right on the edge And I thought the black diagonal line on your avatar was a strut - it's the power line!
poteroo Posted October 18, 2009 Posted October 18, 2009 500' AGL Many new GPS allow for a terrain alert to be set for either 500ft or 1000ft AGL. Yes, it is according to the database - but it seems fairly accurate on my G296. Now, that makes for an increasing number of aircraft able to hold a 500' AGL height. A good place not to be. 300' AGL Keep an eye on any LJR's in your area. The RAAF trainers usually adopt 300ft - and at 250 kts plus, they represent a real hazard. A useful indicator of 300'AGL is that sheep will begin to move as a small trainer passes over them. Much lower and they scatter. You'll be above ag ops too at 300'
Derby Posted October 18, 2009 Posted October 18, 2009 Anyone who flyes near or under a power line except in an emergency is mad and will probably end up dead if not careful
