flying dog Posted October 6, 2009 Posted October 6, 2009 PAN PAN PAN. This is a long - ongoing - problem. I have a Gigabyte Mobo. Model: GA8IPE1000 Pro2 Problem now: The onboard game port. How do I get it working? Original problem: I am using the onboard sound card - gives me Quad sound. But I have an "OLD" M$ Force Feed Back stick. (DB15 connector) so I needed to install a Soundblaster card. For some unknown reason, if the stick is plugged in, FS2004 runs at 7 FPS. Unplugged 30 FPS. It used to work, but I can't get it working again at 30 FPS. I thought I would try using the "onboard game port" but I can't seem to get it working. I have the small cable which goes from the rows of pins to a DB15 connector. I removed the Soundblaster card and put this cable where the sound card was. I can't get it working on this port. At least with the SB card, I could see the joystick and do a "calibration" and see the switches change as I press them, etc. Am I wasting my time trying to get it working or is it worth getting a USB Force Feed Back stick? Anyone?
icebob Posted October 7, 2009 Posted October 7, 2009 Hi flying Dog, I had a similar problem, it appeared when i updated the drivers for the motherboard the old drivers did not delete so it was running on the old drivers not the new, once the old drivers were deleted problem fixed. however it happened again about 6 months later and this time it was the motherboard fault. Had the same issue with the stick and on mine it was a stick fault not the computer. Hope this is a help. Bob.
flying dog Posted October 7, 2009 Author Posted October 7, 2009 Thanks. It kind of helps. But I only installed the drivers I had. NOT from the net. The drivers are the ones I had originally - or so I hope - when it worked.
icebob Posted October 7, 2009 Posted October 7, 2009 Hi, You may find your original drivers are up to two years old, that is why it is good to update via the internet. If it worked before have you tried to reinstall all the motherboard drivers too? Bob.
flying dog Posted October 8, 2009 Author Posted October 8, 2009 Bob, It was a total re-build. New HD. Same drivers/software. But the Joystick kills the machine. :( I may just have to buy a USB one and be done with it.
icebob Posted October 8, 2009 Posted October 8, 2009 Hi, It sort of looks like your joystick is the issue. I would still get the latest drivers from the internet, the joysick may work with them. /not work Bob.
mAgNeToDrOp Posted October 8, 2009 Posted October 8, 2009 Hi,It sort of looks like your joystick is the issue. I would still get the latest drivers from the internet, the joysick may work with them. /not work Bob. Yep would try upate your drivers for the joystick, also look at a bios update for your motherboard, may be worth a shot...
flying dog Posted October 8, 2009 Author Posted October 8, 2009 Bob, Ignoring FS, if I load the "control pannel" and go to game thingies and then select the stick, it all works. X/Y position, "HAT" switch, throttle, "twist", all the buttons. ALL good. But, with FS loaded, the program "dies".
icebob Posted October 8, 2009 Posted October 8, 2009 Hi, OK it looks like it IS or COULD BE an FS problem? Have you downloaded the latest updates? In FS control settings after the first screen have you selected "MOUSE YOKE"? To get mine working I had to reload FS a couple of times. Bob.
