I have a plane I like to fly, but every time I load it, it is full trim back.
So I have to remember to trim it to the middle before take off.
Yeah, pre-take off check. BUT!
It has (originally) got no trim indicator. Got one now. ;)
But where is the setting in the file (which ever one) to give it full trim back?
  • 4 months later...
If you are using FSX, load up your aircraft, set the trim, and all the other things you want eg: If you want to do a complete start up from cold and dark turn everything off etc
I haven't played with FSX for awhile but you then hit 'ALT' I think from memory...save this as a default flight...from then on in whenever you start FSX regardless of airport etc your plane will be as you left it.
