OK Boys (and Girls) - 64 dollar question.
As far as I know (and I could be wrong) there are only two metric nuts/bolts on a Jabiru aircraft.
Where are they?
regards
the one's sitting in the cockpit.... i_dunno
Ooops wrong thread..! :ah_oh:
No doubt about you Tomo, you're a bit of a nut. (I did'nt say nutter:question:)010_chuffed.gif.c2575b31dcd1e7cce10574d86ccb2d9d.gif
BigPete asked a sensible question, so i'll have to ask a Fred to try and get a sensible answer.
Probably the nuts and bolts on the battery leads. All others appear to be AF although I think there may be a BSW or two as well.
Cheers,
Bob
Hi Pete,
I would think the Bing carbie has the odd one or two?
Jack
Yep, full of protein... 016_ecstatic.gif.156a811a440b493b0c2bea54e43be5cc.gif
Guest Maj Millard
Do you know why spark plugs have always been metric ????
We Have a winner ----- That's right Bob - metric on the battery connections, and me with out the matching spanner %#@^.
And it looks like their could be other too. (thanks Jack)
G'day Nev - one thing I didn't consider was the pitch of the spark plugs. but do I need a metric spanner to remove them????
OK Maj I give up - why (are they metric)? (Did the French or Germans have something to do with it?)
regards
PS - You're a funny guy Tomo - listen to Planey - he knows a thing or two.
Guest Maj Millard
They are metric because the Italians invented the spark plug....................064_contract.gif.1ea95a0dc120e40d40f07339d6933f90.gif question.gif.c2f6860684cbd9834a97934921df4bcb.gif:confused:
Plug threads.
Not all of them are. Some early engines.eg. "T" model ford had a 7/8" taper thread. (like a pipe thread) which did not use a washer to seal. Plugs that have metric threads. (Nearly ALL) have all kinds of hexagons and some are A/F (Imperial inch fractions) across flats. The very early method of igniting the fuel in other than compression ignition (diesel) or semi- diesel (hot Bulb) was by a low tension spark where the plug points moved to open from contacting , inside the cylinder and a spark occurred at point separation.. Just a bit of useless historical information..Nev
Many many yrs ago a guy had the same problem, so he invented a thing called the 'farmers friend...'
Yep, you guessed it - the shifter! :thumb_up:
Current Jabiru spark-plugs (NGK D9EA) require an 18mm deep socket, preferably thin-wall. Repco sell them. Get one with a 3/8" drive. Battery terminal hardware is metric on the Odyssey battery supplied from the factory. Haven't attacked a Bing carburettor yet, but it'd be a safe bet the thing is riddled with metric threads.
The old V6 Holden engines were a good example of the mixed threads.
Every thread on the outside of the engine was metric, and all the threads on the inside of it were Imperial (SAE).
You ended up with a metric engine mounting bolt thread and on the other side of the crank case wall you had imperial main bearing bolt threads.
