Bet you it took a while for his sphincter to unclench, wires and aircraft really don't mix! Sounds as though he pulled off a good result in the circumstances - wonder what went wrong?:thumb_up:
A top effort by the pilot here. Anyone who has flown in a yak will know that they fall out of the sky pretty damn quick with no noise up front!
I helped push this a/c back into the hanger a few weeks ago and was shocked by the news. It's great to see that the pilot and pax are ok. :thumb_up:
I drove through the area yesterday, close by where he set the Yak down. My thoughts were on what it would look like from the air. Lots of tiger country there. Hills and forest. From 2500' AGL he would not have had much time to select his paddock. Also, when the noise stops unexpectedly, there is a credibility gap before the trained responses kick in. He did very well indeed.
PeterT
Neil dunn is pretty well know aviator. It is hard to get a radial to completly give up the ghost they will pretty much run with half the engine missing! I'm sure it will all come out in the wash!
Guest Cloudsuck
I would like to know what happened, because those russian radials are very, very reliable.
The only thing that stops them completely is 'Too much air in the carby'.
