burdekin Posted December 29, 2009 Posted December 29, 2009 Whats the latest recommendation on the type of oil for use in Rotax 912 UL
pudestcon Posted December 29, 2009 Posted December 29, 2009 Rotax website says 'API SG or higher' whatever that means Pud
Guest Crezzi Posted December 29, 2009 Posted December 29, 2009 See http://www.rotax-aircraft-engines.com/pdf/dokus/d04432.pdf
bones Posted December 29, 2009 Posted December 29, 2009 Shell make an oil to Rotax specs, its called shell aerosport4, about the same price as good synth oils anyway plus it has the additive approved by Rotax
HEON Posted December 29, 2009 Posted December 29, 2009 Plenty to select from...look at the handbook or any of multible Rotax sites on the net. NEVER USE AVIATION OIL UNLESS SPECIFICLY STATING FOR ROTAX
