Guest Qwerty Posted January 12, 2010 Posted January 12, 2010 I'm looking for an el'cheapo set of Jab doors to get started on my next experimental project. If anyone has a set or even a single door that they could part with I'd be interested. Cheers, Qwerty
Guest Maj Millard Posted January 13, 2010 Posted January 13, 2010 Don't know of any laying around, plenty of Robbo doors around though. Why don't you just knock up a new set of full view jobs, if that's what you've got in mind..........................
Guest Qwerty Posted January 13, 2010 Posted January 13, 2010 Wot is a Robbo door? If I cant get doors, even busted ones, I will have to make my own. I am trying to avoid that for now, I am not the best glasser in Oz (probably not the best one in the room).
pudestcon Posted January 13, 2010 Posted January 13, 2010 Why don't you just knock up a new set of full view jobs, if that's what you've got in mind.......................... How do you do that Maj? I need doors for the T500 and having trouble getting any communication out of TOSG at the moment. Pud
Tomo Posted January 13, 2010 Posted January 13, 2010 Wot is a Robbo door? I'm only Speculating, but I'm a thinkin he's talking Robinson Chopper doors. Am I correct Maj? ;)
Guest Maj Millard Posted January 14, 2010 Posted January 14, 2010 Yes Tommo you are correct, many station hangars I have visited have a set (or two) of R22 robbo doors. Unfortunatly often with a not too pleasant story attached to the chopper itself...there is a learning curve !
Guest Maj Millard Posted January 14, 2010 Posted January 14, 2010 The full view doors that I have encountered lately were on the Lightwing Sport 2000, and on a Savannah VG. Both with welded alum frames covered with a sheet of lexan, with the appropriate latching attached. They simple are made to fit into the existing door aparture with a slight overlap of the lexan for a seal. Both were hinged at the top and were very impressive in flight...........................................................................................
pudestcon Posted January 14, 2010 Posted January 14, 2010 The full view doors that I have encountered lately were on the Lightwing Sport 2000, and on a Savannah VG. Both with welded alum frames covered with a sheet of lexan, with the appropriate latching attached. They simple are made to fit into the existing door aparture with a slight overlap of the lexan for a seal. Both were hinged at the top and were very impressive in flight........................................................................................... Mmmmm thanks Maj, I would prefer to get a set of the fibreglass doors madee for the job but if not to be than maybe what you describe could be an option. It would be similar to the doors on my mate Poll's Gemini although the frame there is not welded. Cheers, Pud (with the shades);)
Guest Qwerty Posted January 15, 2010 Posted January 15, 2010 The full view doors that I have encountered lately were on the Lightwing Sport 2000, and on a Savannah VG. Both with welded alum frames covered with a sheet of lexan, with the appropriate latching attached. They simple are made to fit into the existing door aparture with a slight overlap of the lexan for a seal. Both were hinged at the top and were very impressive in flight........................................................................................... While practical, they are going to look out of place on a Jab. I don't want to build something that looks like is came out of a Mad Max film. Ideally I like a set of doors from a retired jab or a damaged set perhaps.
facthunter Posted January 15, 2010 Posted January 15, 2010 Jab Doors. Have you priced NEW ones? you might get some "seconds" cheap and as Jab repair their aeroplanes they might have some that would not be economical to repair in normal circumstances. Nev
Guest Qwerty Posted January 15, 2010 Posted January 15, 2010 I have been in touch with Jabiru. Thanks for the thought.
Guest Maj Millard Posted January 15, 2010 Posted January 15, 2010 Whats wrong with Mad Max doors ?....worked for Mel..............................................
Guest Qwerty Posted January 15, 2010 Posted January 15, 2010 Maj, Thankyou for your valuable contribution but I am afraid that I am unable to respond to your very interesting and unique post at this time, in this thread, as I am making some considerable effort to, and am determined, not be a party to off topic posting. Your interest and contribution is noted and appreciated, your sense of humor is in particular appreciatred. Should you wish to continue this discourse may I respectfully suggest that a new thread be started in the new "Anything goes" category. Vincent B St F Witworth Qwerty 8th. BBst LLBst.
Guest Maj Millard Posted January 15, 2010 Posted January 15, 2010 Is it off topic ?..it's got to do with doors, and could lead into more interesting info on doors down the way................................................................................................
Admin Posted January 15, 2010 Posted January 15, 2010 Qwerty has been given a 3 day suspension to cool off - posts need to add value to the site for everyone!
