The Civil Aviation Safety Authority has published the following Airworthiness
Directitves between 1 January and 14 January 2009.
These, and other Airworthiness Directives can be viewed at:
Civil Aviation Safety Authority - Airworthiness Directives
Rotorcraft
Eurocopter AS 332 (Super Puma) Series Helicopters
AD/S-PUMA/60 Amdt 1 - Fuselage Inclined Gearbox
Fairing Gutter - CANCELLED
AD/S-PUMA/81 - Fuselage - Intermediate Gearbox Fairing Gutter - CANCELLED
AD/S-PUMA/82 Amdt 1 - Hydraulic Hoist Cable - CANCELLED
Eurocopter AS 350 (Ecureuil) Series Helicopters
2009-0277 - Portable Halon 1211 Fire Extinguishers
2010-0006 - Tail Rotor Pitch-Change Links
Eurocopter AS 355 (Twin Ecureuil) Series Helicopters
Eurocopter EC 120 Series Helicopters
Eurocopter EC 225 Series Helicopters
AD/EC 225/9 Amdt 1 - Fuselage - Intermediate
Below 5700 kgs
Aerospatiale (Socata) TBM 700 Series Aeroplanes
AD/TBM 700/48 Amdt 1 - Main Landing Gear Wheel
Axle - CANCELLED
2010-0005 - Main Landing Gear Wheel Axle
Beechcraft 18 Series Aeroplanes
AD/BEECH 18/17 Amdt 5 - Aircraft Modification,
Inspection and Retirement
GAF N22 and N24 Series Aeroplanes
AD/GAF-N22/52 Amdt 1 - Stub Wing Upper Front Spar
Cap
Grob G115 Series Aeroplanes
2009-0279 - Canopy Jettison
Piper PA-46 (Malibu) Series Aeroplanes
AD/PA-46/19 Amdt 1 - Wing and Fuselage Structural
Fatigue Limitations - CANCELLED
Above 5700 kgs
Airbus Industrie A319, A320 and A321 Series Aeroplanes
AD/A320/8 Amdt 2 - Angle of Attack Sensors
Airbus Industrie A330 Series Aeroplanes
2009-0237-E (Correction) - Oxygen - Oxygen
Containers - Inspection
Avions de Transport Regional ATR 42 Series Aeroplanes
AD/ATR 42/19 Amdt 2 - Fuel Tank Safety Fuel
Airworthiness Limitations - CANCELLED
2009-0276 - Portable Halon 1211 Fire Extinguishers
Boeing 717 Series Aeroplanes
AD/B717/15 - Flight Management System - CANCELLED
Boeing 727 Series Aeroplanes
AD/B727/209 - Fuel System Airworthiness
Boeing 737 Series Aeroplanes
AD/B737/329 - Airworthiness Limitations and
Inspections - Fuel Systems - CANCELLED
AD/B737/331 - Airworthiness Limitations and Inspections - Fuel Systems -
CANCELLED
2009-20-11 (Correction) - Fuel System Limitations - DTSD
2009-26-04 - MLG Forward Trunnion Pins
2009-26-03 - Standby Static Inverter
2008-10-09R1 - Airworthiness Limitations and Inspections - Fuel Systems
2010-01-08 - Wing Centre Section Lower Stringers
2008-10-10R1 - Airworthiness Limitations and Inspections - Fuel Systems
2010-01-09 - Fuselage Skin at Stringers S1 and S2 right, between STA 827 and STA
847
Boeing 747 Series Aeroplanes
AD/B747/51 - Fuselage Frames - Aft Cargo Bay -
CANCELLED
AD/B747/52 - Lower Fuselage Frames - CANCELLED
AD/B747/155 Amdt 2 - Thrust Reverser Pneumatic Drive
AD/B747/157 Amdt 2 - P&W JT9D Aft Engine Mount Tangential Link
2008-10-06R1 - Airworthiness Limitations and Inspections - Fuel Systems
Boeing 767 Series Aeroplanes
AD/B767/242 - Airworthiness Limitations and
Boeing 777 Series Aeroplanes
2009-24-08 - Fuselage Scribe Line Damage
2008-11-01R1 - Airworthiness Limitations and
Bombardier (Canadair) CL-600 (Challenger) Series Aeroplanes
CF-2009-49 - Wing Leading Edge Thermal Switches
and Wing Anti-Ice Duct Piccolo Tubes - Airworthiness Limitation Tasks
CF-2009-50 - Air-Driven Generator (ADG) - Non-Conforming Balance Washer Screws
British Aerospace BAe 146 Series Aeroplanes
AD/BAe 146/137 Amdt 1 - Nose Landing Gear -
CANCELLED
2010-0001-E - Nose Landing Gear
Cessna 560 (Citation V) Series Aeroplanes
AD/CESSNA 560/9 - Minimum Airspeed Placards -
CANCELLED
AD/CESSNA 560/11 - Aileron Fairlead Interference
Cessna 680 (Citation Sovereign) Series Aeroplanes
AD/CESSNA 680/2 - Honeywell Primus Epic System
Cessna 750 (Citation X) Series Aeroplanes
AD/CESSNA 750/4 - Elevator Inboard - Hinge
Brackets - Inspection
AD/CESSNA 750/5 - Reset Circuit Breakers - Replacement
Fokker F100 (F28 Mk 100) Series Aeroplanes
2009-0216R1 - Horizontal Stabilizer Control Unit
Dog-Link Attachment
SAAB SF340 Series Aeroplanes
AD/SF340/54 Amdt 2 - Ceiling and Lavatory Lights -
CANCELLED
AD/SF340/83 - Replacement of Hydraulic Hoses - CANCELLED
AD/SF340/109 - Ceiling and Lavatory Fluorescent Lights
AD/SF340/110 - Passenger Compartment Fluorescent Lights
Piston Engines
Lycoming Piston Engines
AD/LYC/119 - ECi Cylinder Assemblies - CANCELLED
2009-26-12 - ECi Cylinder Assemblies
Turbine Engines
AlliedSignal (Garrett/AiResearch) Turbine Engines - TFE731 Series
AD/TFE 731/24 Amdt 1 - First and Second Stage Low
Pressure Turbine Discs
AD/TFE 731/26 Amdt 1 - Low Pressure Turbine First and Second Stage Disc Suspect
Material Properties
Pratt and Whitney Turbine Engines - PW4000 Series
AD/PW4000/6 - Inspection of Critical Life-limited
Rotating Engine Components - CANCELLED
AD/PW4000/10 - Engine Stability Improvements - CANCELLED
Turbomeca Turbine Engines - Astazou Series
2010-0004 - Engine Rotating Assembly - Third Stage
Turbine Wheel - Inspection / Removal
