icebob Posted April 5, 2010 Posted April 5, 2010 Below is a link to a calculator for True Air Speed. May be of intrest to someone. Bob. Paragon :: True Airspeed Calculator
icebob Posted April 5, 2010 Author Posted April 5, 2010 Hi Cficare, All the variables can be manually changed, provided you start with the correct figures it is only out by .002. Have been informed that the next update will allow it to be downloaded, should fit on a mobile phones memory. Bob.
Barefootpilot Posted April 6, 2010 Posted April 6, 2010 A good rule of thumb is add 2kts per thousand feet so 5000' you add 10kts its rought but not to bad to get a good idea.
Guest Howard Hughes Posted April 9, 2010 Posted April 9, 2010 Add 2% per thousand feet and you can't go wrong! 85 knots @ 5000 feet = 94 knots 100 knots @ 5000 feet = 110 knots 150 knots @ 5000 feet = 165 knots :thumb_up:
Tomo Posted April 10, 2010 Posted April 10, 2010 Add 2% per thousand feet and you can't go wrong!85 knots @ 5000 feet = 94 knots 100 knots @ 5000 feet = 110 knots 150 knots @ 5000 feet = 165 knots :thumb_up: :thumb_up::thumb_up:
Guest palexxxx Posted April 17, 2010 Posted April 17, 2010 Add 2% per thousand feet and also another 2% per increase of 10 degrees celsius and you can't go wrong.
