XP503 Posted April 13, 2010 Posted April 13, 2010 Hello everyone, I have a little Maycom hand held scanner and I am wondering if anyone out there knows if i can increase its range, would it be as simple as buying a different (larger) aerial for it and wacking it on?
Guest ozzie Posted April 13, 2010 Posted April 13, 2010 bigger stick may work but remember VHF is 'line of sight'you might have to climb a hill.
BigPete Posted April 13, 2010 Posted April 13, 2010 Shove an aerial on a pole (the higher the better) and run some coax down to the scanner. regards
jcamp Posted April 13, 2010 Posted April 13, 2010 Shove an aerial on a pole (the higher the better) and run some coax down to the scanner.regards Might lose more in the coax than you pick up, generally need a RF amplifier up the pole too to avoid expensive low loss cable. Note for Radio you need 50 ohm coax, amplifier and connectors not 75 ohm TV stuff Alternative is power (up) and earphone (down) cable with the whole scanner up the pole
ahlocks Posted April 13, 2010 Posted April 13, 2010 I was picking up Temora CTAF traffic from 45nm away during Natfly, using a handheld (A24) with a discone base station antenna connected to the BNC fitting. It wouldn't be practical or legal for transmitting, but it was certainly handy to listen in to get a feel for what the traffic was like at Temora before venturing out to the airport.
Bidgee Posted April 13, 2010 Posted April 13, 2010 Hello everyone,I have a little Maycom hand held scanner and I am wondering if anyone out there knows if i can increase its range, would it be as simple as buying a different (larger) aerial for it and wacking it on? That may help. Make sure the aerial matches the wavelength eg a UHF aerial wont help. Buy a quality brand too. Have a look here - Untitled Document. These guys do a good product and are an Aussie company. All you'll ever want to know about antennas. Scott
Guest Cloudsuck Posted April 14, 2010 Posted April 14, 2010 G'day Dave, you will need a high gain, ground indepentant base station antenna for the 2 metre amateur band and RG213, 50 ohm coax (Dick Smith). Diamond make a good base antenna. Andrews Communications - Diamond Antennas or http://www.strictlyham.com.au/diamond/base-antennas/x-series-base-antennas The 2 metre amateur band is very close to the VHF airband so there is no tuning involved. I can talk to you further about it at the airfield, I'll be out there Fri, Sat, Sun this week.
Tomo Posted April 14, 2010 Posted April 14, 2010 Thanks, what's Coax? Coax is aerial cable - not trying to get someone to do something! Actually it's called Coaxial cable because it consists of two concentric conductors separated by an insulator.
