Drew Ford
Information
  • Aircraft
    Antonov 2, Piper PA28, Skyfox, Jabaro, Thruster T500, Power shute.
  • Location
    Australia
  • Country
    Australia
Recent Profile Visitors
Drew Ford's Achievements
Member
Member (1/3)
  1. If you think of the birds confined in the pressurised space within the 747, then no matter what the birds were doing, sitting or flying, their weight would be the same on the aircraft. If the birds were out side of the aircraft and hanging on to it, their weight would also be the same, but if they all let go and flew in their own right, then the 747 would experience a weight reduction. Like if a 747 was piggy backing the Shuttle, on a flight from LA to Florida, the 747 would experience the weight of the Shuttle attached to its back, but if the Shuttle all of a sudden flew off and detached itself from the 747 then there would be a weight reduction on the 747s pay load. So what ever happens inside of the 747 does not alter its overall weight.
  2. There is logic as to why it is improbable that there is life on other planets.
  3. Hi Guy, I lived in Lismore when Ces & Alf Fyfe had an Ag Op there They hired a DH Dove & Cherokee 144 A local had a Piper Archer 300 IFR. Nice place Lismore Local area is great,Byron, Evans Head, Casino, sealed runway, with a big hump in the middle, so in nill wind if you were lined up at one end and the regular RPT Focker lined up at the other end, you could not see each other!
    1. Guy s
      Guy s
      Hi Drew and yes not a bad part of the country to live in and the Casino strip been shorten a fair bit so the hump has become more of a hollow now. Ces & Alf names is not familiar to me as I've only been flying for about 10yrs now. I know a few in the Aeroclub would know them and 1 would be George Sommerville who was the Cfi for many moons. Cheers Guy.
  4. Sounds very adventurous. You need everything in top condition, including yourself and the Aircraft. Have plans B & C. and be prepared for the unexpected in regards to the weather, you & your passenger, and the Aircraft. Keep a diary of the lead up to to trip, The idea, The finances, The planing. Preparation, Lessons learned. What were good decisions and what better decisions could have been made. Would make for a good short story/adventure for other aviators.
  5. There was the unfortunate case of an early model Skyfox hired to a Solo Student, who practiced his left & right turns, after doing a prolonged turn, he noticed one wing tank was empty, thinking he will not make it back to base, he decided to put it down in a paddock, resulting in substantial damage to the aircraft. Tears. I remember in California a pilot did a refuel the night before his flight so he could get away first light in the morning. The fuel gauges read back to front, that is, when Full, the needles went to the left! However someone observed the refueling, and when the pilot left, the thief emptied both tanks resulting in the fuel gauge needles going all the way to the right. (which on most aircraft would indicate full fuel.) The next morning the Pilot did not pick this up in his checks as he knew he had refuled the aircraft the night before. The result was tears. Need to be careful not to slip into the habit of doing checks robotically. Take your time and actually look at the item you are checking. A Chief flying Instructor in N.Z. Ardmore, was caught out doing what he always told his students never to do, that is to assume an item is checked without actually checking it. Both of us got into a PA 28 (I was converting my Oz PPL to a NZ PPL.) The CFI said "I will show you how to get to the other end of the field, it was a long taxi around with numerous clearances, he did the take off checks, and when it came to FUEL ON, he touched the tap on the floor, but did not actually look at the taps position-( it was in the OFF position.) So after our run up, we line up, got our take off clearance, full power, then just about lift off, the aircraft pulled firmly to the right, then the engine quit! We narrowly avoided hitting the base of the Tower and ended up off the strip on the grass. Post flight analysis. After 20 minutes of searching for the problem the CFI found the fuel tap in the OFF position. There were many expletives used, which are not printable, but the CFI said the School has a policy of never turning the FUEL OFF during the day, only at the last flight of the day. Well that solved why the engine quit, but what caused the Piper to firmly turn to the right at lift off?. Another 20 minutes of investigating control surfaces etc, etc, the problem was located in the cockpit. This Piper Cherokee had an auto Pilot fitted and the ON /OFF switch was on the panel directly in front of the throttle. So when you applied full forward, throttle, your knuckles hit the front panel and turned the Auto Pilot ON . The bug on the Auto Pilot was on a setting to the right of the runway heading, so as the aircraft was ready the leap into the air the Auto Pilot was ready to turn onto the preset heading. The diagnosis was correct, the problem was in the cockpit. The Pilot in command.! No one hurt and no damage, except for some pride perhaps. But it could have ended up differently. The long taxi to the other end of the field certainly was a factor, had we taken off at the Club House end of the main runway we would have had fuel exhaustion past the point of no return. So it can happen to the best of us.! And don't trust something because its brand new. A new Aircraft was being assembled at the airfield by its happy owners. By mid day all was ready for start up, after several attempts the Rotax fired, the aircraft was tied down and the throttle set to idle. The motor was left running, whilst maps, headings, weather, was checked and rechecked, and periodically the CHT was checked, all was fine. First leg of the trip was Camden to Mudgee across the Blue Mountains. Then suddenly after about half an hour the engine suddenly stopped!! The next day it was found to have aluminium shavings in the fuel line!! If they had taken Off immediately after assembly, they probably would have come down around Katoomba in Tiger country. My saying is that you may not always get into the air, but if you do, one thing is for sure, you will always come back down again, and how that will happen largely depends on the Pilot in Command. Cheers, stay alive and fly safe.
  6. Great pics of Thruster in NZ. NZ has produced some good pilots, David Belton, (Thruster Aircraft Director) youngest N.Z. Commercial Pilot to hold that rating. Also Ken Asplin CFI was from NZ. operated a school in W.A. and in Sydney.
  7. Incidentally The picture on my Profile pic, is of the Opel which holds the altitude record 33,000 ft + Sadly the owner pilot a few weeks later had a major structural failure and did not survive.
  8. Hi Stuart, Yes getting the photos sorted and writing small post scripts so you know the location and story behind the pic. I have purchased a multi-photo scanner, from Melbourne, should be here on the weekend, I will scan all my photos (about 6,000) several hundred or so it appears, to be about flying. As soon as I scan them I will send you the originals. Andrew. OK the Photos are scanned and I have sent the originals, by post with heaps of paraphernalia, original Thruster Owners manual, news paper articles, crash reports, Thruster Advertising, Air Show participation, etc,etc. Enjoy cheers Andrew.
  9. Love the look of your Antanov 11 11 seater, used as a work horse, for fertiliser spreader, float plane, glider towing etc,.
  10. Hi Stuart, Yes getting the photos sorted and writing small post scripts so you know the location and story behind the pic. I have purchased a multi-photo scanner, from Melbourne, should be here on the weekend, I will scan all my photos (about 6,000) several hundred or so it appears, to be about flying. As soon as I scan them I will send you the originals. Andrew.
  11. Amazing to see the log entry of your Pilot Certificate. Yes I think you were one of those natural people who took to flying quiet easily. My training Thruster at Moruya, I used to fly it down from The Oaks west of Camden NSW. Was a long day to get back before last light. It has now the black pod (was Blue) after a student bingled the nose, I repaired it and had it spray painted.
  12. Hi Deskpilot, I did have some videos from the 1980s, but they deteriorated. I have got many photos which I can send coppies, the term "Deskpilot" is a little frightening, are you licenced or associated with a registered flying school, or are you a Deskpilot whilst waiting for your dream bird to be serviceable again. lol. I loved the Thrusters, but the industry has moved on and there many good birds out there, but probably not as affordable as a well maintained Thruster.
  13. Hi Yenn, Yes I believe there are many Thrusters flying, no factory support, but many technical people pool their knowledge and owners can keep their machines in the air. I was the factory CFI and I learnt to 3 point them on, but an analysis of damage to the aircraft if the student got it wrong or panicked when the aircraft started kangaroo hopping down the strip, made it prudent to teach the students a way out if they could not 3 point them, so we also wheeled them on. In the end a typical landing was sort of half 3 pointer and half wheels on. Regards Andrew.
  14. Hi Stuart, You must have been one of the originals as well. My CFI. PE. Licence with the AUF was 0541 which is one of the earliest CFI licences except for David Belton and Mr Dinsmore the National flying coach. I live in Harris Park at the moment until March 6th. then Oseas. Have to find a way to get the photos to you. if you have any ideas give me a ring on 0490447795 Regards Drew Ford.
