RFguy
Everything posted by RFguy
  1. yes, that is a dynon servo which is a crude but effective device- a stepper motor and a gearbox. . that looks more like part of an autopilot than a control system trim servo, but could be. Stepper motors have high inherent torque and dont need much gear reduction to get the required torque (for this application). turbs illustration post is a screw jack - (or lead screws) are generally run at high ratio with high speed small motors and there is significant resistance to the screw jack moving when force is applied to the actuator tends to impose high friction forces dependin gon the construction (screw thread - acme screw jack) or reciprocating ball screw. A screw jack reduction ratio is the force application circumference divided by the screw pitch
  2. from the article. "Aircraft engineer Peter Marosszeky" says you need 25 hours at 16yo . that's a crock of sh1t. Many kids go solo 8 to 16 hours and dont fall out of the sky. It's the old guys that need lots of hours. Now, the instructor's appraisal and evaluation, that is something different. I'd done quite a few glide approaches, and simulated engine failures (including upwind ) by the time I had my first solo, so I was prepared for say, an engine failure in circuit.
  3. I dont think we should cease guessing/ evaluating. Remember two experienced pilots.....If control surface control failure can be eliminated, ---Only a stuck control surface control is my thought. spanner stuck in the elevator or roll control etc ? if it is not that, I a, guessing the flying pilot had a medical episode while the other pilot was looking out the window looking at something else, and then things got slow and the aircraft was too slow, too low and now too late to do anything about it. What else is plausible ????
  4. so what do the other 35% who do not agree to pay more do ?
  5. I learned spiral dives , how you get in one, and how to recognize them and terminate them. wings level and throttle to idle ... Pretty basic stuff. Not recognizing them will ensure a quick trip to the obituary columns. and I learned and practiced how to hold the airplane in a 60 deg banked 360 deg turn nose correct attitude holding altitude and hit your own wake. That was a pass....
  6. I'd buy the bonanza . And a J160 for when I wanted to go cheap, and hold my J160 to a high maintenance level. (WRT- Bonanza) - I feel older certified aircraft are very good value for money , with their advantage of 50 years of knowledge about them and most bugs known.... These days I probably wouldnt touch a factory built aircraft model any less than 10 years old- it hasnt had enough time to accumulate some ADs !
  7. ooh ahh forward trailing edge taper wings like the low wing brumby.
  8. now comes the more advanced stuff, interspersed with the instructor sending u up to do a few exercises from time to time.
  9. A pet project of mine, actually Thruster88's idea is a into headphones (insertion, aux or inline) audible and visual warning that a stall is imminent. Really good IMUs for $7 are now available , along with dual ported dual airspeed sensors (splice into ASI system) would do this job well..... Would go a long way to preventing this . I have caught myself occassionally not scanning my ASI often enough when I am busy looking at something, like for another airplane at the same time I am coordindating a tight descending turn etc fortunately when I am missed the scanm for a few seconds, I've always had plenty of airspeed, and the airplane (PA28) is heavy and takes (forever) to slow down if I get careless. Unlike a 300kg jab which will run out of inertia three times as quick.
  10. the 'universal board' could be done these days with lots of available integration IE its not a intercom or radio or anything, IE the inputs and outputs are universal, audio and all. it's just a matrix connections to get all the audios the right level, split combined or whatever, all the PTTs etc routed etc etc aux audio mixed in etc . because of the difference in impedances etc, it's hard to have just a board with amplifiers and pots. leaving someone purely to connect the wires, and config done over a wifi connection (from a hotspotting phone) to the net.
  11. there seems to be a market for a "matrix box", due to the lack of electronics people I forsee a PCB with screw cage connectors for 'anything' that can be configured to hook up 'anything'. IE connect all the items , just get the grounds in the right place, and that is all. The labour is the problem. If you can set up the product such that the owner provides the labour in terms of merely connecting wires to the board (and in no particular order), then a high level person remotely can program the board (and if required, have the installed/ owner plug some jumpers in like a checkerboard. said board needs to be able to sample and feed back to the high level person that configures (sets gains, polarities etc of signals) discuss.
  12. welll at Oshkosh this year I watched a airplane departure traffic jam over 2km worth (looped back on itself) and it was about 32C and 90% humidity... all chuggin away, some decided to shutdown. OK on the performance. I know the airmaster IFA has the most numbers for Jabiru 3300s, but I would think a 912 and a after-turbo would be a better user package (air air gets thin, doesnt matter....) . Much nicer to hang a CS off. I'd be careful of how much is hung on the front of the Jab engine, the airmaster that people use- the moment of inertia is miles beyond the jabiru max spec (but I dont know if Jabiru factory just set that number to suit their own propeller, or not, IE if it is just a number, or if there is any science behind it.) . Still, I have heard of NO Airmaster IFAs coming off jabs. Understood on the static RPM completely sucking. yeah that's expected ...... I'd actually like an airplane like that that did about 170 TAS at 12,000' / 4h endurance to go and see my mum in. . that would be a nice improvement over my 120TAS.
  13. What's the 200 kts with ? with a Jab 3300 and airmaster CS prop and 1 pax and full fuel ? How does it compare to a Lancair 360 ?? (76 sq ft wing, 500kg empty) , that's about a 200kts plane, also.
  14. yeah I dont see why this needs / should be in LSA category- surely VH-EXP? A Va of 145 kts implies for a 3.8g aircraft, a clean stall of at least 74 knots.... or 59 kts for 6g aero category. Sounds like quite a bit of runway required and skilled pilots. IE - like a Lanceair. Plenty of aircraft ahead of pilot incidents there There's been a couple of PA28s (suspected of) losing their wings due to a neg g manouver at high airspeed, (neg g which is a lower load factor (g limit) than pos g) .
  15. yeah as I read it , just get a class C transit clearance from the mil guys and life is much easier, now. IE you will be accomodated if at all reasonable and possible, compared to, in the past, the opposite.
  16. 10nm transmit range on a skyecho, is about the limit when the installation permits it. you'll likely see full power ADSB transmitters from at least 20 to 40nm away. again, depending on the installation.
  17. the tubes and rag of aircraft size will not measurably affect it . the tubes are fairly small compared to a wavelength and will tend to just re radiate whatever they intercept. That being said, you want to stay at least half a wavelength away from any metal in the direction you want to go, about 15cm. The antenna is in the top half of the SE2, so you want that in the clear. flat plate larger than a half wavelength will start to hurt, though. The GPS is just as important, it needs a good view of the sky. (in the top of the box) . if you have a torx bit, take it apart and have a bit of a look
  18. SO, what are these "bolts found to be loose on other aircraft" that we are hearing about ?
  19. so the guy in the seat had their seatbelt on eh ?
  20. there was a common room in our setup, but I think you are gonna just go out for dinner, there are some cost effective joints to eat at. but I couldnt be arsed cooking dinner, and there is a good healthy- style organic supermarket down the road, we ened up getting breakfast and lunch food from there, they sold really good sandwiches we'd pick up on the way home and put them in the common room fridge with our other food like fruit, yogurt etc. Stu and I are healthy eating types , most of the time, so that was easy. mixed with beer, of course.
  21. Hi Mike. I consider the rooms secure, I would leave my laptop and tablet in the room... only would take my passports with me in my backpack, that's all.
  22. Huntsman's are fine. they'll eat the moths, silverfish, etc in your aircraft
  23. Looks fantastic Mike ! just as long as it doesnt get too hot up there. maybe a white paper shade, japanese origami style.
  24. I think the most useful info and tidbits I have learned about flying has come from glider pilots.
