RFguy
Everything posted by RFguy
  1. agreed if its in a fuel tank and you do NOT want blobs coming adrift and blocking inlet. good reason to have finger strainers.
  2. Skip, maybe for your experimental application, just some decent automotive fuel tank/ fuel pump gasket silicone etc Repco Australia | Auto Parts Store - Aftermarket Car Parts WWW.REPCO.COM.AU Repco Australia | Auto Parts Store - Aftermarket Car Parts WWW.REPCO.COM.AU
  3. although your 1 hour flight will chew up $50 of fuel and $17 of engine time ? maybe you can get a bit from the locals.
  4. any any idiot can get an airplane airborne IF they manage to keep it straight on the TO roll. landing though is a different story.
  5. It would depend on how fast the air could be pushed out the float bowl (breather/equalization passages).
  6. redeveloped... yes that might be a good start. The transponder construction is quite solid a completely different beast. . But the radio looks like a good design start but never finished- IE looks like the person designing it left the company 75% through the design. and items never got sorted. From a modern perspective, its was built like something from the early 90s. The biggest issues I have found have been that the factory alignment method is wrong in many places, so I roll my eyes. O've seen quite a few surface mount component faults - mechanical, the chassis is a bit light for SMT components (flexure). However, when aligned corrrectly and no faults, they work well. The most rapid head shaking comes from seeing bills they gave people for alignment of $600 and they didnt get it right or find the fault..... I have reached out to them in the past with suggestions, but they dont seem to want to talk.
  7. I wonder what the fuel pressure gauge was reading.... That might be the $64 question to whether the fuel was water, (no viable recovery method at 1800' (120 seconds) or the tank draw briefly starved (due to a manouver) or there was a fuel blockage. putting that aside, coul dhave been another fault. Carb fault ? But M-S carbs are pretty simple. Wonder how long it was since she practiced a full CFMOST full troubleshooting proceedure. (IE initial check (gauges, carb heat, pumps on, change tanks) , plan, pax brief, comprehensive check (include check is primer locked ? try different things, throttle position that works ? , bad mag ?, primer normal ? try different mixtures) .
  8. Microair, from my experience, I wouldnt recommend.
  9. hmm Non invasively, the only way to figure if there is fuel in the lines is to tap the line and watch the pipe vibration frequency. but if the lines post the selector are full of water, you are dead in the water. so.... it needs to be detected between the tank and the fuel selector cock. and at a velocity of about 27cm/second in 1/4" line at cruise (8 gph) , that aint long o do something about it fuel injected system will behave differently. Primer comes from elsewhere. Might keep engine alive with primer if primer has access to the fuel ? WHat's the primer pumped quantity per push in the cherokee ? something like a 2" travel in a 1/4" bore every 3 seconds... no, that's not going to keep it USEFULLY alive. you are better to fly it.
  10. The Funke looks good. inbuilt 2 place intercom.
  11. yeah I was wondering as what rate it would pull the water out of the float bowl . maybe reduce throttle opening is better because it creates lower pressure and might assist vapourizing the water. dunno . water VP is only 2.5 kPa. fuel is ~ 30-60.... . 20 " of Hg pressure below atm .. 67kPa below ATM so no..... Does anyone know what happens in the real world witht his question ?
  12. Does anyone know what the windmilling prop RPM will be for a Cherokee in best glide at WOT setting. (IE minimum intake restriction likely results in higher windmilling speed). Reason for question. In the case of water in the lines, how long does it take after changing tanks to ingest all the water through the engine, and given the low vapour pressure of water, will it even be effectively pulled into the intake system at all ? or will it just fill the float bowl and stop moving ? The 1/4 ID lines is only 31.7mL per meter. say a 1.3m worth from the fuel switch = 41mL, or at 7000mL/hour = 21 seconds.
  13. 1500' is hard. and she had to turn into the wind. room for one steep descending U turn, nothing else. Sounds like she did fine. It's one thing to practice, another thing to be severely time compressed and do all the steps. She says she didn't switch the tanks and was dirty with herself about it. But I dunno if there was enough altitude /time to switch the tanks and have the good tank deliver fuel to the carburettor....... especially if the lines were now full of water... I wonder if she looked at fuel pressure, that gauge is there also. But you might show fuel pressure if it was water, also. "fluid pressure" a filter missing off the pickup eh. a few things.... Was the aircraft perfectly level when she was draining out all the water ? I might drain them empty if there was that much water. 4 gallons in the right tank eh that's not much, that might be something to consider if you'd pulled a litre of water out of the wing.... but fine if you intend to go over to the fuller tank for landing phase. It's what I do, I have run my right tank down to 4 gallons and go onto the left tank with copius fuel . Piper floor air vents - close them for ditching ! I will remember that. The water in the fuel eh. I've never seen water in my fuel.. not ever, and the way pipe caps are done the only way water is getting in is in the source.... My guess is the engine fuel system got a bucket of water in it and that was the end of that.
  14. honest with themselves and others, and wiling always to accept and evaluate criticism are the pilots that I can fly with. Remember what Viper said, " A good pilot is compelled to critically evaluate themselves so they can improve" etc.
  15. yeah, there is variation across Jabs, especially early types. but in general, they have hot wires through the firewall, and no alternator disconnect from the battery. Both I am sure may lead to fires. But, in factory built LSA ' the manufacturer knows best' and there isnt any recourse to changing anything without leaning on the airspace regulator. The manufacturer of a factory built LSA having the last word is a feature of LSA. Someone help me understand WHY this is a feature ? I guess is does work for most LSA manufacturers, they respond to industry best practice more than J. appear to me to do.
  16. waste of a good airframe. unfortunately also took the life on an innocent.
  17. Great you are now PA28 familiar. I have 29 hours on type, now. They are the Commodore of the skies. easy to get parts for. not like Mooney's where there is a fight over rare 2nd hand parts ... yeah a useful beast. with one up, 2 hours of fuel, sea level, 25 flaps and a WOT before rolling, it will get off the ground very quickly. After I sell the Jab I will look for a 19- .... Savannah or Nynja/ RANS/ Zenith etc. maybe a sonex....
  18. Take a look at the pressure versus flow curves for the pump you have in mind to determine suitability. Bit of pressure is useful to reducd chance of vapourization bubbles in hot weather / high altitude (high DA) ULP ops. You don't need much pressure to drive the Bings, as long as you get the flow
  19. Cowra to Wagga for lunch. Wagga is another place I have not flown to myself, have been with others. Managed to figure out the taxiways. Locals very friendly. Lots of flying school activity in circuit, all had ADSB enabled so I could both hear and see what was going on on the tablet. Lodged real flight plan on the way back complete with sarwatch. Excellent Cafe at the terminal with broad operating hours. 5-17 weekdays, 5-1330 sat, 10-17 sunday. access from GA parking , get in and out via Gate 3. good coffee and OK food.
  20. So, got a instant reply from the council. which is good. Parking on the grass is free. Parking on the hardstand is space limited and $10/hour.
  21. There is a limit of the voltage produced without load. Regulators and alternators will survive it if load is disconnected. Dont worry about that. Danny have a look at a mid 70s schematic of a Piper Warrior or something, that will show the right way to do things in terms of battery and alternator disconnect. As for standards- in GA you will not satisfy the criteria unless there is a battery isolator. GA is driven by criteria to meet to ensure reliability and safety. There are generally two types of criteria that would apply- there may be a specific requirement in AC43 AND there will be the catch all 'thought shallt make every possible fault remote' elsewhere. As for 19/24, I doubt there is any requirement at all, (it would be in the ATSM) since Jabiru factory airframes have unfised, uninterruptable hot battery wires that are not particularly thick going through the firewire through metal grommets - a fire waiting to happen- (the only problem with Jabiru airframes IMO- otherwise they are excellent) . RAAaus doesnt make technical specifications, it refers to them.
  22. Anyone used this tool ? scroll to bottom and click START https://www.atsb.gov.au/avdata
  23. might do this trip in next couple of weeks any suggestions ? main airport probably most convenient. Camden Haven also looks friendly. -glen
  24. I put a report in. I was fair. identified possible causes and mitigation strategies...
  25. Living with a flying school with 6+ planes airborne in the VC is busy. 1 RPT is not... But it wouldnt be any worse than Bankstown or Moorabbin. But maybe it is worse without tower OR defined approach/departure methods. Maybe' its the most dangerous airspace in the country.
