47
Everything posted by RFguy
Cirrus 22M Shelter Cove Airport, CA
RFguy replied to red750's topic in Aircraft Incidents and Accidents
getting out of the sydney basin is not too bad, in favourable condix. Just pick your day so that you can get some altitude (not squashed down by clouds) and there are routes that have paddocks here and there. Likelihood is you are flying something in RA that can land in a paddock, IE you're not flying a Lanceair . As Nev says, there are ways to do things with less risk. Flying is about the highest risk activity that is legal, a friend said to me. somewhat true. If you must fly, then you'll have a RPL or higher and get a clearance above it all. -
The bulk of this post is that it rings true of what my instructor , Rob Glenn, once said. "Pilots are decision makers : any buffoon can land a plane, but the decisions you make will have a bearing over whether you live to tell the tale " Cowra YCWR (central west, inland) to Goulburn YGLB 125 Magnetic, (located near the coast on the great divide) . 76nm over undulating tableland farmland . needing to swap some planes around, getting a lift in another plane at GLB then somewhere else. Day before the GAF looked positive and nice. but the GAF at 6am was troublesome. 4 hours of fuel on board for the 45 minute flight - plenty for a diversion that I anticipate as there is PROB30 for fog at goulbourn until 10am and thus I MUST nominate a viable alternate with a TAF and carry fuel . (Bathurst YBTH, 60nm from track) Goulburn is famous for its fogs but usually clear by 0900 local. A big mass of NS and CB with heavy showers (per the GAF) from the west and vertical development chased me out of Cowra at 0900 , I departed VC AD at 100 kts climb (500 fpm) to get away from it, knowing that I would not be immediately want to use it as an return , or indeed any nearby ADs as alternates. By the book, the forecast at the AD has to be good for 30 minutes after departure . So sort of broke that rule but technically there is no TAF.... but its pretty obvious (without a TAF) what was coming to a reasonable person. Get to 7500 ' . temperature +1C. smooth, clear over ground, under the next layer of cloud at 12,000-15,000 estimated. it's a little misty outside . humidity is up... there is a cold pool of air up here. was warm on the ground at Cowra ! Got about 1/2 the way , near Crookwell , where I have landed before, and there is a sharp line where a sea of low level cloud about 700' above all terrain begins . As far as the eye can see to the east, and south down the range and north up the range. There is no way I can land anywhere over that whole region. While according to the METAR, the is patches of blue sky over Goulburn, It's one thing to duck through 1000' of cloud that has bases at 7500 and tops at 8500, its another thing to do with the 100' thick cloud at 750' AGL in the mountains....... With a 100' thick layer at 700 AGL, and you are above it all, if you have an engine failure anywhere over any of that expanse of land and cloud, I guarantee you will die because you'll only know where the ground is when you hit it. So, I do a 10nm orbit think for 10 minutes, reduce fuel flow from 31 lph (67%, @peak EGT, 2450, 105KIAS 1900lbs AUW@ TO) to 25 lph , and I get a tiny bit of roughness and 20-30 RPM lost....troubleshoot by applying a bit of carb heat , it's likely to be a bit of carb ice..... since conditions are favourable and I have a high manifold vaccum......... so no big deal, I can see the ground still. No need for carb heat in this case, the high manifold vaccum is obviously causing some low temps, so I increase fuel flow to 28 lph (~ 98kias) and it goes away but will keep an eye on it..... I start to head north for my alternate, 60nm.... clear and nice - as my closest ADs at cowra, young, parkes, orange, are all under rain on the radar, and it looks imposing out the window. I dont want to go near the CB and TC . flyng for a short time, METAR at Goulburn looks better, hmm, alright lets have another look. so head back that way to the edge of the cloud. Nope doesnt look any different. In fact I can see higher cloud behind it to the coast. Mark texts me and says its raining lightly to the east of goulburn. nail's in the coffin. Turn back. head NNW, descent to 6500 , toward Cooming Park ALA, dodge a few heavy rain bands , after 15 min, I notice that it's cleared around Cowra now (I am east of Cowra now north of Wyangla Dam) so then I turn west direct to cowra. For all the rain and dark clouds, it is suprisingly smooth. I did stay at least 10nm away from ANY of the shower activity and heavy cloud, so that's a good thing. Uneventful landing.... WIll try another day. glen.
Looks like a good outcome to me. I would have done the same. You're not going to glide your way out that one. compared to this pilot the other day 500' over the tops of the Wollomi national park, a large region of sandstone bluffs and deep ravines. .. What was he, scared of heights ? flying under low cloud. insanity ? I fly over that extreme tiger country region in my Archer but only when I can get > 5500 feet OVER the tops of the hills, (IE 8500 west or 9500 east) then I have a survival chance and I know all my decision points and which paddocks I am going to they are marked on my map and ozrwy map. If I was flying at 500' above the hills in that region, I'd be so horrified by the view that I would put my hood on and go onto instruments so I didnt have to look outside. -
too many engineers have never been technicians dont put diodes in parallel, they DO NOT current share. but by all means put two in parallel for redundancy, just rate each diode at the full requirement Diode- use a diode with a Vr of around 40V. that will have a far lower Vd than a 150V diode. If you like Vishay, suggest https://www.vishay.com/en/product/97219/ https://www.vishay.com/docs/97219/vs-175bgq045hn4.pdf At Tj=125 and If of 20A, it will have a Vforward of about 0.3V, IE about 7Watts to dissipate. bolt to a chunk of aluminium, at least 20 sq inches surface area, 3mm thick. it will need a silicon washer and bush under the tab against the heatsink, since the tabs are live.
From my rather critical POV, the UL twin problem indicates the these issues are ahead / beyond the UL staff and the buy is goign to need ot odo their own system design , and perhaps get advice .... My thoughts are , isnt this an obvious failure mode / system design problem that should be a well worn path by now for UL. Beware of twin of anything in electronics, same goes for everything else. Ultimately, the error though lies with the pilots not doing their checklist (check alternator contribution / battery voltage post start)
Advice on idle : (documentation : ROTAX OM915, 912 "Section 2.1 " engine start : for iS engines -Section "3.4) After engine start" "Set linearized throttle position in a way that the engine runs at approx. 2000 rpm for approx. 2 minutes." then "Set linearized throttle position in a way that the engine runs at approx. 2500 rpm until oil temperature reaches 50 °C (120 ° F)." If you run a 912ULS at 1400rpm you'll foul up the plugs because the mixture between front and rear cylinders goes wild. (one end goes rich - front ? cant remember) .
The FI rotax does not begin to charge the battery until 7 seconds or so over 2500 RPM. So after oil pressure is established, need to get RPM up to 2550 etc so the battery starts charging, this is obvious by looking at the ship battery voltage. Until that time, the ship battery is in discharge for internal ship loads (and not yet being charged by ALT-B) The ALT-A begins to run the ECU at about 1200-1300 RPM, approx. Very low RPM in flight (how ?) might cause some ECU confusion and require ECU to be powered by the ship battery if RPM too low to run the system from ALT-A/B Just discussing the rotax here because it's a good example of how it can be done. Putting aside miscellaneous annoyances and sensor issues of the FI rotax.
take a good look at the fuel injection pump current requirements under various condix, they can pull a fair bit, and that you might have BOTH pumps on due to design (or error ?) Given that good quality, sealed non liquid electrolyte batteries generally do not have sudden failures, it's probably a good option as a power source. a strong schottky diode or MOSFET schottky implementation with some sort of current limit would be a simple and reliable option. A big schottky with say only 20V 30V reverse barrier will be pretty low voltage drop. maybe something like 12 or 14 gauge wire will serve as a current limit....maybe aim for wire resistance = diode drop under normal conditions, as a starting point. that will be fine as long as the charging system gets up to 14.4 , 14.6V region
Mike I gather the UL system has one alternator and one ship battery. usually the single alternator is doing double duty and I think that's a bad idea, since the engine systems are not isolated from the troubles and switches and breakers and ge-finger trouble of the user.... The only way to really get away from it is a 2nd power source., or perhaps an independent feed from the battery with its own isolation relay (or a 2nd battery only for the UL so that buys you an hour etc, and some switch that you can cut over the Ul to main ship battery- but then you have a single failure point in the cabin maybe.... so, some thought required to escape the single power feed issue. The UL systems having its own feed from the battery and own isolation switch etc is probably the simplist.
Mike On the UL electrical - I wonder how the dual ECU setup power is set up. Given the issue and what you;'ve told me, it might be worthwhile to consider modifications / additional systems. a recent story... I know a bit about the electricals of 915 rotax's these days. I had to find/fix a charging intermittant. The Rotax has two alternators - A and B (ALT A, ALT B) A is rated about 15A, B at 30A. "A" normally runs the ECUs (all rotax electrical) (thru their 'fusebox/switchbox"), B is routed to the ship to run systems and charge the ship battery. . In case of a failure of ALT A, the the system commenderes the B ALT and the ship is cut loose to run on ship battery. At start because there is no A or B, ship power is routed to the ECU C input until A(or B) gets going) then once running the ship power source is removed. and I can confirm it all works well. Everything including the dual injection fuel pumps are powered from the rotax control box, nothing can stop the rotax once it's going.... (except individual ECUs can be disabled- LANE A, LANE B) . I've demonstrated removing the battery terminals while the prop was going AND disconnected the output of ALT-A and it fails over onto ALT-B immediately cutting the ship lose.
surely those rectangular square cornered windows are no good for high cycle count airframe pressurization cycles?
FWIW https://www.airservicesaustralia.com/aip/current/dap/BUNAD01-175_30NOV2023.pdf accident report at 1445 local
remarkable only for experienced on type, no doubt . There has to be more to this. No sane pilot goes off into full on type crosswinds with little time on type. ....
This is the sort of crash where you want the battery to have a isolator at the battery, like GA aircraft. Maybe even double pole. and have non cracking insulated covers on exposed terminals
no issue with the door open of a PA28 . might cost you a bit of drag , that's all. and a bit of noise. as for creating a problem near stall? no. Not compared to what those big wings are doing. Not sure where that wive's tail came from. (no offence to the wives, either)
pilot survived. 'trapped in the crash' lucky it didnt catch fire. https://www.abc.net.au/news/2024-03-01/plane-crash-bunbury-airport-authorities-responding/103536362
but you dont turn the ignition for the stall warning test, you turn on the MASTER switch, and also run the fuel pump to dump the gascolator
piper door is easy to reclose in flight (it also has the upper latch) AS LONG AS you do it as the POH tell you to. (open storm window, close vents) . that storm window is something special isnt it ? I thought it was for getting a bit of cool air and for your ground crew to pass you the loading manifest through the window, but no, its for looking where you are going when you cant see where you are going.
well with an old Cherokee, you wont have any problems with the door staying shut. 🙂 🙂(although I fixed mine)
Then, you can have the worst of both worlds and get a MID WING ! fly a Viking SF2A Cygnet. Markdun has one. I have flown one of these as co pilot. nice https://en.wikipedia.org/wiki/Viking_SF-2A_Cygnet
It is not true for all low wings that they are hard to get out of if flipped. It would be easy to get out of a flipped over PA28 cherokee etc if it flipped over. Has a bit tall fin, also. I have no idea how you might flip one over though. PA28 is a low wing but has a side door. (and a baggage side door you can get in and out) . also in a PA28 you have a roof over your head. no sunburn. I have seen a couple of low wing coanopies at oshkosh and they had pins around the canopy that unlocked the whole thing to come off into pieces... Brendan, its time you got a Cherokee.
