Hi everyone just a few questions,
Question regarding the ETC in my schools Jabiru J160C. How exactly is the ETC wired up to the aircrafts electrical system? Some aircraft have an ETC on/off switch (which ours has) and with others the turn co-ordinator (maybe it's vacuum pumped and not electrical?) comes on with the masters. Looking through the J160 electrical wiring diagram the ETC should only function when the avionics is selected on and the ETC switch is selected on, however on many occasions I have jumped into the plane and turned the masters on to deploy flaps for inspection and the ETC has started spooling up because someone left the ETC switch on from the previous flight which is pretty easy to do because the switch is so small and under the throttle.
Question regarding air induction in the J160C. Just reading through the J160C manual I noticed that the Jabiru can also intake cold air which enters through a duct on the left side of the cowling (which is deffinetly there) however it says there's a flapper valve to select either hot or cold air. Our Jabiru came with the cabin heat factory mod so the lever inside the cockpit is marked "Cabin Heat" - I've never used it but I guess if I did pull it, hot air would come out right? is it a manual operation to change the induction from hot air from the muffler to cold air from outside? Or is it just a matter of pulling the cabin heat lever slightly so just cool air gets through? At the moment I just kick open the side vents to draw in a very very small amount of cool air (which manages to cool down my hand and nothing else )
Hope I didn't complicate that. Appreciate everyones input.
Thanks,
Andrew
