Thruster87
Everything posted by Thruster87
  1. C47 [only for about 20min] You mainly use the trim to fly straight and level due to the large mass of the A/C. Using the stick [small corrections] it tends to hobby horse due to the delay in responce Cheers
  2. Don't be so density about it.
  3. 6.1 Maintenance may be performed on amateur-built experimental aircraft (including kit-built aircraft) by:  An appropriately rated LAME;  A member of a group of owner-builders who has satisfied the maintenance procedures training requirements (each member of the group may only maintain those parts of the aircraft that he or she has fabricated);  An eligible owner-builder; or  The current sole owner of an amateur-built aircraft who: º is able to satisfactorily demonstrate that he or she has previously fabricated and assembled the major portion of an aircraft of a similar type; and º has satisfied the maintenance procedures training requirements. CAAP 42ZC-2(0): Maintenance of amateur built aircraft Found the requirement (each member of the group may only maintain those parts of the aircraft that he or she has fabricated); to be interesting Cheers
  4. The man flying the 3 kites is in his 80’s, and he's from Canada. He comes to the Washington State International Kite Festival every year. His skin is like leather as he normally flies with his shirt off. He is deaf, so when he flies we hold our hands up and wave them for applause. He flies 2 kites with his hands and the 3rd one is attached to his waist. Enjoy! The music is just perfect for his performance! http://www.youtube.com/watch_popup?v=nr9KrqN_lIg
  5. It took me a year working most days on finishing a Zodiac 601xlB kit. De -burring every hole and edge, I reckon consumed half the build time,but it was still very satisfying project. Cheers
  6. In the real world it would be hard to find a person with all the necessary attributes to give you a definitive answer on all types and construction methods as each job specializes either on theory or practical aspects.The LAME wouldn't know if a longeron or stringer is needed in a certain spot[the Aero- Eng would] but can tell if it is riveted on properly.That's why the L4 only does a walk around and checks paper work for W/B etc. Cheers
  7. What you really need is to have a structurally sound designed aircraft in the first place and that can only be worked out via extensive testing by Aeronautical Engineers [Load Tests/Stress Analysis using various methods depending on available funds] or a test pilot with a parachute. L4's only do a external inspection and rely on your check procedures prior to first flight.You only have to look at what happened with the Zodiac 601xl, it is now the most tested design in history of LSA aircraft. Cheers
  8. It's only done 32hrs since new and 8 hrs since replacement thru bolts fitted.It appears that these engine can get quite tight once hot [spoke to Jab] but like I said earlier wanted to get a more informed cross-sectional opinion from actual /owner operators of their Jab 3300's Cheers
  9. You're right on the money as I would like to hear from an experienced hand who can judge between normal and abnormal stiffness with these engines not the theory behind piston engines as I'm a LAME Cheers
  10. But I find it hard to interpret which part of the engine is causing the stiffness when hot and also what is normal due to my lack of exprience on the type.Without doing an actual compression [gauge] test hot vs cold how would you know. Cheers
  11. Just wanted to hear from other Jab 3300 owners on what it feels to rotate the prop cold and hot.How much compression kick back.Mine gets fairly tight hot vs cold very little kick back if any. Cheers
  12. Not in aviation, the LAME is at the top of the food chain for certifying aircraft to be airworthy and it takes longer/more experience to gain a license then a degree. The Aero E works behind a desk doing the designs Cheers
  13. Do you know the difference in the knowledge base of a LAME/AME/Aircraft Mechanic compared to an Aeronautical Engineer.I think you will find the Mechanic a lot more up todate on the regs as he needs to sign off/certify all his work on a day to day bases as opposed to an Aeronautical Engineer.Cheers
  14. I'd also consider going to a place like repco and going thru their o-ring tray. Cheers
  15. Jabiru do sell parts as well and you may get compatable parts from motorcycle shops [also most modern o-ring materials are compatable with the use of ethanol] . Cheers
  16. http://www.youtube.com/embed/Cd6C1vIyQ3w
  17. WHY MEN ARE NEVER DEPRESSED: Men Are Just Happier People -- What do you expect from such simple creatures? Your last name stays put. The garage is all yours. Wedding plans take care of themselves. Chocolate is just another snack... You can be President You can never be pregnant. You can wear a white T-shirt to a water park. You can wear NO shirt to a water park. The world is your urinal. You never have to drive to another service station restroom because this one is just too icky. Same work, more pay. Wrinkles add character. Wedding dress $5000. Tux rental-$100. People never stare at your chest when you're talking to them. New shoes don't cut, blister, or mangle your feet. One mood all the time. Phone conversations are over in 30 seconds flat. You know stuff about cars. A five-day holiday requires only one suitcase. You can open all your own jars. You get extra credit for the slightest act of thoughtfulness. If someone forgets to invite you, He or she can still be your friend. Your underwear is $8.95 for a three-pack. Three pairs of shoes are more than enough.. You are unable to see wrinkles in your clothes.. Everything on your face stays its original color. The same hairstyle lasts for years, even decades. You only have to shave your face and neck. You can play with toys all your life. One wallet and one pair of shoes -- one color for all seasons. You can wear shorts no matter how your legs look. You have freedom of choice concerning growing a mustache. You can do Christmas shopping for 25 relatives On December 24 in 25 minutes. ___________________________________ Men Are Just Happier People NICKNAMES If Laura, Kate and Sarah go out for lunch, they will call each other Laura, Kate and Sarah. If Mike, Dave and John go out, they will affectionately refer to each other as Fat Boy, Bubba and WWWildman EATING OUT When the bill arrives, Mike, Dave and John will each throw in $20, even though it's only for $32.50. None of them will have anything smaller and none will actually admit they want change back. When the girls get their bill, out come the pocket calculators. MONEY A man will pay $2 for a $1 item he needs. A woman will pay $1 for a $2 item that she doesn't need but it's on sale. BATHROOMS A man has six items in his bathroom: toothbrush and toothpaste, shaving cream, razor, a bar of soap, and a towel. The average number of items in the typical woman's bathroom is 337. A man would not be able to identify more than 20 of these items. ARGUMENTS A woman has the last word in any argument. Anything a man says after that is the beginning of a new argument. FUTURE A woman worries about the future until she gets a husband. A man never worries about the future until he gets a wife. MARRIAGE A woman marries a man expecting he will change, but he doesn't. A man marries a woman expecting that she won't change, but she does. DRESSING UP A woman will dress up to go shopping, water the plants, empty the trash, answer the phone, read a book, and get the mail. A man will dress up for weddings and funerals. NATURAL Men wake up as good-looking as they went to bed. Women somehow deteriorate during the night. OFFSPRING Ah, children. A woman knows all about her children. She knows about dentist appointments and romances, best friends, favorite foods, secret fears and hopes and dreams. A man is vaguely aware of some short people living in the house. THOUGHT FOR THE DAY A married man should forget his mistakes. There's no use in two people remembering the same thing! SO, send this to the women who have a sense of humor and who can handle it .... And to the men who will enjoy reading it.
  18. I think you will find that there are no gaskets used on th 3300A only "O" rings and sealants Cheers
  19. You will find that there is no gasket as the 2 halves of the plenum are joined together using Loctite 515 cheers
  20. http://pal-v.com/
  21. Thank you for your reply.That's the way I put it back just wanted to make sure and blowing air made the slide lift up. Also used a bit of dry moly lude on the internal shaft. Cheers
  22. What is the Correct orientation of the slide on a Bing 94 ? Cheers
  23. The ATSB has released its latest statistical report – Aviation Occurrence Statistics 2002 to 2011 – providing the most up-to-date portrait of aviation safety in Australia. There were 130 accidents, 121 serious incidents, and 6,823 incidents in 2011 involving VH-registered aircraft. General aviation operations continue to have an accident rate higher than commercial air transport operations—about four times higher for accidents, and nine times higher for fatal accidents in 2011. Most commercial air transport accidents and serious incidents were related to reduced aircraft separation, and engine issues. Charter operations accounted for most of the accidents, including two fatal accidents in 2011 within air transport. Air transport incidents were more likely to involve birdstrikes or a failure to comply with air traffic control instructions or published information. For general aviation aircraft, accidents and serious incidents often involved terrain collisions, aircraft separation issues, or aircraft control problems. General aviation incidents commonly involved airspace incursions, failure to comply with air traffic control, and wildlife strikes. In most operation types, helicopters had a higher rate of accidents and fatal accidents than aeroplanes, except for in charter operations. Even though the fatal accident rate is generally higher, helicopter accidents are generally associated with fewer fatalities than fixed-wing aircraft. The figures and insights from the report are helping the ATSB concentrate its efforts on transport safety priorities. The report also reveals that many of the accident types are avoidable (especially for general aviation) and can be prevented through good flight management and preparation.
  24. WHAT,,,,,,who do you think would maintain a certified engine in a certified aircraft,,,,a LAME perhaps, and to a higher standard than most of the ultralights getting around ! It takes years to be let loose as a LAME , to maintain a Jabiru ,or any RAA machine you only have to sit in the left seat till someone says your a pilot, this obviously renders the certificate holder the smarts to do the required maintenance , Exactly, now you are starting to understand my point of view. Cheers
